Archive
I was setting up the DL-Max Webcam for Asus G1S but there was an error on it, a notification was telling me that the CMOS_Camera_D-Max_GD Windows 7 Ultimate 32 bit was failure to set up.
Cannot set up anymore, I used Windows 7 RC1 7100 and it works well recently, and some drivers works fine too and set up properly. Please help.
Read moreHi,
I have a cannon ip2772 printer. Some times it cannot work properly and I cannot get a good print
Read moreHello, I am using Webcam max 7.1.7.2 latest version and also FME 3.1 to flow, however I found some error. I am using 250 or 300 kbps for the broadcast bitrate and FME is on automatic mode but when I click access and begin to switch to flow 2500 kbps and this was a big trouble because it could not flow like that. The image not appears on the player and does not have a high upload. Please help to solve this issue.
Read moreI attempt to make some plays and it works fine but when I open the Camtasia and begin to get some record, I couldn't view it. I could view only going up and going down but when I do so I can rotate in a circle. Someone help? Please tell me how to resolve it. (If you want some video I can send you one).
Read moreHi there,
When I tried to format the hard disk with 150GB disk space in Windows, an error message appeared.
Hi guys, I have a Camtasia and want to copy some VODs, however, I am facing with some troubles.
1. Sounds not working - the voice is working fine but the sounds of the games did not. Is there anybody knows what kind of troubles is this?
2. The VOD sounds bit wavy, definitely why?
My settings:
Tools --> Options -->
Video: Screen capture rate: 30 frames /sec
Capture codec: TechSmith Screen Capture Codec (this is error, I guess)
Audio: Microphone (SB Audigy, the microphone is connected to the computer)
Audio Format: PCM, 22.050 kHz, 16 Bit, Mono (is this sufficient?)
Is anyone knows about Camtasia and what...
Read moreMy Rockmelt is not anymore recommended to connect on webcam (WC) in my latest browser. And also Rockmelt is declining to access in every game, together with chrome. I want to use Opera but it was failed, seem it is disturbing by submitting forms in every sent. I could not open also the Internet Explorer (IE) or the Firefox because it is very weak. And so I decided to open Comodo and signed in but I have encounter by a critics that want to ruin my time value of unit building. Not interested.
Read moreHi Experts!
I am trying to download a file from internet.
It takes too much time and while downloading the file my computer is hanging as well as I could not download the file.
Is any swift download software by which I could do the job well?
Thanks,
Read moreHello, I have a TouchPad and I installed Skype, but how come that I could not view my friends and why is it they can see me? Even though, I know that the features is not good. However I can listen to them yet couldn't view them. Is there someone encountered this similar issue and knows how to fix it? Thank you.
Read moreI encountered error with the Skype and the 2011 Multipoint server. When I have set up the Skype, and use this programs I notice that I freeze every now and then. Also when I use the Excel, had a same situation. Is the Skype has a connection with this error like freezing the program. Is there anyone has same problem with Skype and how could I resolve it? However, when I am not using Skype the computer works normally but when I am going to use the Skype same error I experience. Please help and thank you.
Read more
