Archive
How can i open a inpage file in Corel draw? Please kindly help to open inpage file in Corel draw.
Read moreWhen I turn on my computer, the fans spin for just an instant, and the front panel LED and the LED on the main board remain lit, but the unit won't turn on. It had been running fine one night, and the next day it was like this. I replaced the small battery on the main board but that didn't help. Could it be the power supply?
Read moreHello,
I started using Virtual DJ for my music. On my system I have installed Windows Vista 32bit.
When I want to open file I got an error message. This problem I don’t have no idea how to solve.
Can someone help me to fix this?
For all files I keep back up on external HDD.
Thank you
Cherryl
VirtualDJ
Decompressing this file in memory would require 44Mb of contiguous memory.
Your system has only a total of 147Mb available free segments (out of the 2047Mb), and they are too fragmented to hold a contiguous buffer.
Therefore, the song will be loaded on-the-fly from the...
Read moreHey,
My sister gave me her laptop Toshiba windows XP pro. On it I have installed Virtual DJ home. A few days ago my laptop shut down (my battery was low). When battery was recharged after starting up laptop I’ve received error message. How can I fix this problem? Any suggestions are welcome.
Thanks in advance
Nelson
AutoIt Error
Line 0 (File “C:Program FilesVirtualDJrunVDJ.exe”):
$Line = _StringToHex( StringStripWS($aRecords[&x], 3) )
$Line = _StringToHex( StringStripWS($aRecords[^ ERROR
Error: Array variable subscript badly formatted.
OK
Read more
Hey guys,
Recently I have installed windows Vista. In last a few days I have noticed that something is wrong when I want to play some games. I don’t know were is the catch.
To backup saved game I copy all in a different folder.
Now I have two folders in the game directory and on other place. When I start the game I got an error message.
How can I fix this?
Please don’t tell me that the solution is to delete or start all over again.
Thanks
Donald
FATAL ERROR
FATAL ERROR: Could not load world...
Read moreHello,
For scanning documents I am using ControlCenter3. Even I have reinstalled whole system with Windows Vista now I am having some problems with this program. When I want to scan something first he needs a few seconds to start and than I got error message. How can I fix this? Please help
Thanks
Rae
ControlCenter3
Scanning failed.
Please try to scan the image again, if the error happens again please restart your computer, and then try to scan again.
(CC3-205-0301f04)
OK
Read moreHi all,
When I want to copy files from my camera I got an error message. Usually I copy or move files directly from the camera. Now it is pretty irritating because I got this error message that I don’t know how to fix.
On my system I have Windows XP without SP2. Even the batteries are ok. Did anyone had an issue like this?
Thank you
Deryl
Files were not obtained from device
Cannot obtain all files from this device. Please ensure that the device is connected properly, or that the battery is charged.
Files already copied to hard disk will...
Read moreHi everyone,
Until recently I haven’t used Adobe Acrobat. This is a question from a newbie,and every suggestion is more than welcome.
In Adobe acrobat I wanted to have time or date inserted. On the internet I have read more suggestions but none of them was successful.
Please help by step by step if possible. OS: Windows XP SP2
Thank you
Lonnie
Adobe Acrobat
File check in failed. The server said:
“Invalid data/time value
A date/time field contains invalid data. Please check the value and try again.”
Please ensure you have completed all required properties with the correct information and try again.
OK
Read moreDear All,
This is pretty stressful situation for me. On one project I am working pretty hard I can’t save.
I know that it has a lot of layers but what is how it supposes it to be. Is there any chance that this file can be saved like it is?
OS Windows XP SP2, Adobe Photoshop CS 5.1
Thank you
Hillary
Adobe Photoshop CS5.1
Could not save as “E:...Panorama.full.01.psd” because the document exceeds the 2.00G limit for saving Photoshop files.
See Help topic “Saving and Exporting Images” for more information.
OK
Read moreHello everyone,
I have installed on my computer with Windows Vista Adobe Photoshop CS4 Extended. Until this upgraded version of Adobe Photoshop I didn’t had any problems with this program. I could work on it without any problems, now when I want to open it I got error message. Is there any solution for this problem? I would really like to work in this version of photoshop.
Thank you
Z
There was an error launching the adobe Help application.
You may need to re-install the application and the Help component.
OK
Read more
