Archive
When sending an email or just typing an address in the “To:” field, I am getting a list of addresses. There are various autocomplete recipients which I sometimes accidentally mistyped. How can I remove it? I am using MS-Outlook 2010. Please help.
Read moreHi!
I just want to know if there’s a way that I can setup my PlayStation 2 and communicate with my Cisco Linksys WRT54G.
I want to know more about the setup in the router itself and all the required cables needed.
Read moreHello,
A few days ago I got my problems with Adobe Reader 9.0 started.
Currently I am using Windows 7 but I didn’t install anything new of updates. But I wanted to update Adobe reader so I got basic plug in.
When I tried to install it I got an error message.
Has anyone idea what should I do?
Thank you
Kelly
Adobe Reader
Invalid plugin detected. Adobe Reader will quit
OK
Read moreHi everyone,
There is something strange with my computer. I haven’t done anything unusual.
Yesterday when I tried to shut down computer error message appear.
OS Windows Vista. What is wrong? What should I do?
Thank you
MP
dwwin.exe – DLL Initialization Failed
The application failed to initialize because the window station is shutting down.
OK
Read moreHey guys,
I have done some back up of files into external USB HDD.
Now whenever I try to start any of files with PDF extension I got an error message.
What should I do with this?
Anti virus program is not reporting that files are infected. OS Windows XP
Thank you
Lorie
Adobe Acrobat
File check in failed. The server said:
“Invalid data/time value
A date/time field contains invalid data. Please check the value and try again.”
Please ensure you have completed all required properties with the correct information and try again.
OK
Read moreHello,
Recently I got some error with Adobe Reader. It is updated to a new version.
When updating was done I have restart computer.
After that When I wanted to run PDF file I got an error message.
OS Windows Vista
Thank you
Jessie
LoadRetun[1].pdf – Adobe Reader: AcroRd32.exe – Application Error
The instruction at “0x20bc12af” referenced memory at “0x00000000”. The memory could not be “read”.
Click on OK to terminate the program
Click on CANCEL to debug the program
OK
Cancel
Read moreHi,
I got NetCam. Recently I reinstalled OS and update it to Windows XP SP2. On this reinstalled system I need to install NetCam center, and Installation was successful. Error message appears when I wanted to connect to the Internet.
Can some one help me with this issue?
Thank you
Hugh
NetCamCenter
Can’t bind port 80!
Please make sure there is no application or instance of NetCamCenter uses this port.
Or assign another port number for NetCamCenter.
OK
Read moreI can’t seem to save my appointments in Outlook 2010 and Exchange Server 2008.
The error message I am receiving is: The connection to MS Exchange is unavailable.
Outlook must be online or connected to complete this action.
I can save my emails but I can’t add calendar entries.
My Outlook 2010 is connected with my MS-Exchange.
I am also the administrator of my Exchange Server.
How can I resolve this?
Read moreHello,
I am not shore what is the problem. My friend borrowed me his laptop, OS Windows XP. When start up was finished error message showed. This is so confused. On the Internet I try to search the answer but I couldn’t find.
Please help
Thank you
Liz
Application Error
Exception EInvalidPointer in module Ad-Aware2007.exe at 000042D5.
Invalid pointer operation.
OK
Read moreHi,
On my laptop I wanted to install HP printer Laser Jet all in one. Installation was successful. Before restarting, test page was printed and it came up well. When I restart computer error message pop up. Laptop Soni Vaio Windows XP SP2
What should I do?
Thank you
Ted
HP ToolboxFX – en-US
HP ToolboxFX has encountered an error and can not recover.
Please re-start HP ToolboxFX, or re-start your PC.
You will not be able to receive alert message, or use other HP ToolboxFX feature until HP ToolboxFX has been restarted.
Windows version: Win32NT – 5.1.2600.0
HP ToolFX...
Read more
