Archive
On my computer I got JetAudio 8 free version. I wanted to upgrade it to a new version, and my friend got me a copy on USB. My computer didn’t find any viruses on USB. When I run set up, error message appear. It won’t let me to make updates.
Please help
Thank you
Julilo
jetAudio
An error [-5006: 0x80030005] has occurred while running the setup.
Please make sure you have finished any previous setup and closed other applications.
If the error still occurs, please contact your vendor; COWON
[http://www.cowonamerica.com].
Report
Detail>>
OK
Read moreHey everyone,
I have some issues with VirtualDJ and I don’t know what is wrong.
Recently I got Numax Mixtrack pro, everything with this hardware is okay. My friend told me that VirtualDJ is great software for it and I install it on my computer (Windows Vista).
Everything is fine with the hardware, but when I want to start VirtualDJ there is error message. Any suggestion, answer will be appreciated.
Thank you
VirtualDJ
The controller has not been detected.
Please plug the controller and start VirtualDJ again.
OK
Read moreI am in my account in Exchange and I was looking for the Out of Office command for about 30 minutes now but I can’t find it in the Tools menu. I tried to manually reset the Tools menu but it still doesn’t show. How can I refurbish and bring it back? Help anyone! Thank you.
Read moreHello,
Recently I started using Avid Media Composer and I like it on my work. So I have decided to install it at home at my computer, OS Windows 7 professional. When installation was finished and I wanted to start application Error message pop up.This is confusing because Installation is well done, but after all I got error message.Did anyone had similar or like this experience?
Thank you
Leonore
AvidMediaComposer.exe – Entry Point Not Found
The procedure entry point ?Release@MutexTenure@Threads@@UAEXXZ could not be located in the dynamic link library CoreThreads.dll.
OK
Read moreDear all, For scanning I am using Spawer Doctor and for removing the program Your Uninstaller.
This time I run first Your Uninstaller and after that Spawer Doctor. When all done, I have restarted the computer. In recycle bin I have found some files that were removed, and I clicked to empty it.
After that when I wanted to click on partition C: I got an error message.
What should I do?
Any help will be appreciated Thank you Key OS: Windows XP
C:resycledboot.com
C:resycledboot.com is not a valid Win32 application.
OK
Read moreI usually browse the internet and subscribe to the RSS feeds that I like the most and it will automatically go into my Outlook. I really like this feature and it works great with me. I also grouped those feeds according to their categories and topics. But when browsing the feeds in Outlook, it appears with a long list which I need to categorize again. How can I fix it? Is there any way that I can make Outlook copy the folder of my created feeds in Internet Explorer? Thanks.
Read moreWhen I am trying to answer an email in Outlook, my username automatically show up in the body of my reply email. When I hit any key to make the first word and start editing my message, my username will appear on screen. How can I fix it? Is there a way to turn off this feature? If so, how can I do it? Thank you in advance.
Read moreI am trying to import contacts on my Excel sheet into Outlook but I am receiving error: “An error has occurred in the Microsoft Excel translator while getting the contents of a file system. The Microsoft Excel file <myfile> has no named ranges. Use Microsoft Excel to name the range of the data you want to import.” How can possibly do that?
Read moreI have deleted MS - Office 2007 and upgrade with MS-Office 2010 Pro Plus. But I am having error installing MS - Office 2010.
It keeps saying, “Setup has detected legacy groove and Microsoft Groove Sever software on this system.
You must uninstall all legacy Groove and Microsoft Groove Server software before installing or upgrading to Microsoft SharePoint Workspace.
For more information, see your Microsoft SharePoint Workspace administrator.” When I searched on the web for some solutions, I found out that I should open my Groove and follow what was written in the error message.
But I cannot open my Groove. Now, I...
Read moreI successfully installed Groove Server 2010 but when I am trying to connect with the server and enter my server account code and account server, I am receiving this error message: “Sharepoint Workspace did not detect any authentication certificates suitable for your identity. Please contact your administrator”. Have I done anything wrong with the installation? Can someone please help me?
Read more
