Archive
My company is upgrading to Exchange 2010 from Exchange 2003. For now I have transferred myself ahead of them to Outlook 2010 and do some testing. In the process of testing it, there were no problems in sending and receiving emails. However, I received the following error message when I tried to activate the automatic out-of-office reply. The error is stating: Your automatic reply settings cannot be displayed because the server is currently unavailable.
Try again later. I went through the terminal server to use Outlook 2002 to verify the out-of-office information and was able to do so. The new...
Read moreAfter my PC was rebooted I faced the following message (Check the attachment). The dialogue box’s title is ‘Isass.exe Application Error’. It bears the message -
The instruction at ‘0xoo401082’ referenced memory at ‘0x00000000’. This memory could not be ‘written’.”
Please have a look at the screenshot attached.
If you have any ideas please let me know what can be done.
System Shutdown
This system is shutting down. Please save all work in progress and log off. Any unsaved changes will be lost. This shutdown was initiated by NT AUTHORITYSYSTEM
Message
'C:WINDOWSsystem32Isass.exe'
terminated unexpectedly with status code
-1073741819. The system will now shut down...
Read moreMy Android gadget rebooted automatically and I received the attached ‘Force Close’ message. You can guess how annoying it could be. All on a sudden it my android is malfunctioning. I would appreciate your comments about this thread. The attached ‘Force Close’ message may give you some idea which application is responsible for the unexpected reboot. The highlighted portion of the attachment is provided as an example of Force Close error message. Your prompt feedback would be a real help in the circumstances.
Sorry
Mail has stopped unexpectedly.
Please tell HTC about this problem.
To help HTC improve...
Read moreAn error message (the attached one) appears on the new computer bought by my parents. I used PCM over application to transfer all their files and application from the old one to the new HP brand PC. As the HP Support Assistant automatically tried to update itself, the error popped up.
Even if I click ‘ok’ to avoid the issue, the message appears right in the center of the monitor every now and then. I have uninstalled HP Support Assistant going to Control Panel’s ‘Software Utility’ option and rebooted my PC. But this won’t get rid of the error, and...
Read moreMy problem has to do with virus attack in my PC and I want your advice regarding how to get rid of those. I suspect it’s a sort of redirect virus and the problems started probably a few weeks ago. I will start with searching troubles I faced while using internet. Clicking on the search links I can sometimes find the correct pages but often the opposite happens. Very often search links ends up in ‘not available’ page. But I find the accurate site If I cut and past the link from the address bar into the search bar.
At...
Read moreI use Ubuntu 10.04 operating system in my PC. I tried to install Adobe Flash CS5 in my machine. As I start the program it provides the message ‘Error initializing Java Runtime Environment’ (As the attached picture shows).
Please help me out of these with a solution.
Adobe Flash CS5
Error initializing java Runtime Environment.
You may need to reinstall Flash.
Read moreI have invested a lot of my time in trying to build and rebuild a conductive environment to illustrate Microsoft business products.
I received this error prompt while trying to come up with an application service and power pivot proxy: “error.
login failed for user ‘NT AUTHORITYANONYMOUS LOGON’.”
What could be the problem?
Error
Login failed for user NT AUTHORITYANONYMOUS LOGON.
Troubleshoot issues with Microsoft SharePoint Foundation,
Correlation ID: 65092bb0-3425-4e41-aYOc-c3b288279241
Date and Time: 8/29/2011 1:14:40 PM
• Go back to site
Read moreI was told that someone can be able to access a hidden folder from C:Program FilesApplications. Unfortunately I am admin on OS as well but I cannot access the folder.
I have attached pictures of the error messages that I get.
Thanks for helping!
Applications
You don't currently have permission to access this folder.
Click Continue to permanently get access to this folder.
Applications
You have been denied permission to access this folder.
to gain access to this folder you will need to use the
Security tab.
Read moreI am upgrading MS Exchange 2003 server to Exchange 2010. I had an idea to create another server and install the MS Exchange 2010 on it and then simply migrate everything such as email, settings, etc., from the old MS Exchange 2003 to the newly installed Exchange 2010. However, several errors came up during the installation and I need help in fixing those errors. I will show you more about the errors through TeamViewer. Just let me know. Please help.
Read moreIt is very normal for computers to face different kinds of problems for instance the ones shown in the message below. User init.exe, application error, the application failed to initialize properly, Check Ok to end this application, tasking .exe, application error, same message as user init.exe,.exe has encountered a problem and needs to close etc.
Init.exe - Application error
The application failed to initialize properly (0xc0000142). Click OK
to terminate the application.
Read more
