Archive
I am using Intel pentium 4. INtel Desktop Board D845GLLY. I am using windows XP. After set up I installed win2k_xp. I mean Intel Extreme Graphics Driver. Yet I am facing a serious problem. When I play a high resolution movie, the screen become dark totally. Then I can hear the sound only. I have to restart the computer. Then everything is normal.If I wish to play again the same problem occurs. Now is there any solution for this problem?
Read moreThe boot process of this machine was just super slow and immediately after opening windows you could get advertisements, pops up balloons, and many other logos of various programs. Note that this before you clicked on absolutely nothing! We also had many error prompts on the screen. The computer functionalism went low and got worse because it took more than half a minute for windows explorer to start. This is after the computer had been fully rebooted. Applications such as excel also took almost 60 seconds to open. It was really slow. What do I do?
I am encountering problems logging into Outlook Web Application or OWA and Exchange Control Panel or ECP. As a background, we are using two CAS/HUB Servers and the Barracuda HLB (hardware load balancers) with SSL offloading using the one interface configuration. I can successfully log on to OWA/ECP directly from each CAS/HUB server. However, if I do not log on directly from the CAS/HUB servers, I was unable to log on. Can you possibly explain why this is happening?
Read moreI am in the process of creating an exe application with Lab VIEW 2010 professional development system SPI 32-bit. I used windows 7 professional 64 bit. Unluckily I always get this error when I press the build specifications/new/application (exe).Anyone one out there with suggestions?
Error 1498 occurred at Get LV Class Default
Value.vi
Possible reason(s):
LabVIEW: Library has errors. Fix the errors before
attempting this operation.
Complete call chain:
Get LV Class Default Value.vi
AB_UI_Initialize_Framework.vi
AB_UI_FRAMEWORK.vi
AB_CreateNewWizard_Invoke_CORE.vi
Continue
Read more
I have a Windows XP computer and been perfectly using Notepad application for a long time now. But recently, when I am working with my Notepad, I received an error 0xc0000096. I don’t know what this error is all about but when I exit the application and try to start it again, it will work fine and then when opening it the next time, the same error message will appear. I have attached the exact error message and code. Please help me on this as I am using my Notepad in developing my HTML-based website. Thanks a lot!
A few hours ago my friend called to seek help from me because his machine couldn’t run a certain program. He received this error message, Application error (0x0000153). “This particular application you want to run cannot run well”. Note this message is a translation from Turkish.
DKKeyboardStat.exe - Uygulama Hatasi
Uygulama duzgun olarak basIayamadi (0xc0000l35). Sonlandirmak icin TAMAM dugmesini tiklatin.
Tamam
I bought a very good dot.net application known as MS Expression from Microsoft.
This will assist me when illustrating the profile trace abilities of speed trace dot.net.
Early last week I installed a program that just deleted the application.
I have no idea how but it messed it and 24 hours ago when I attempted to open expression design I got this error message.
Microsoft Windows
Microsoft Expression Design has stopped working
A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
Read moreI installed Nerve Express Software on my machine a few weeks ago. My computer had XP installed earlier on. Now when I press on the Nerve Express icon the program fails to start and shows this error message,
Protection violation
Check if correct marx protection key is plugged in.
Read more
All the time when I have finished browsing and I want to close down a window,
I receive an error prompt that reads “IExplore.EXE -Application Error message.
This is shown in below picture. How can I remove this error?
IEXPLORER.EXE - Application Error
The instruction at "0x62304390" referenced memory at "ox62304390". The memory could not be "read".
Click on OK to terminate the program
Read moreHD videos cannot play well in my computer! It is super slow and the images lag behind the audio! Any ideas?
When I try to play HD videos for instance MP4 on my machine, the videos are super slow like in very slow motion .Do you think this has something to do with the hardware or my system is just not made to play these videos? Could it be a problem with the system software? I have already installed KLM codec pack and the specifications for my machine are as follows:
- 1 GB RAM DDr1
- Intel Celeron processor 2.66GHz
Display adapter. NVidia Geforce2...
Read more
