Archive
Recently, I cannot download any .exe files on my computer. I am thinking that maybe there is an issue with the Administration access. But I am the only user and the only Administrator of my computer. I did not receive any updates from Microsoft. I am thinking that maybe it was because Microsoft has finally ends their support on Windows XP but I am receiving error that says I am not the Administrator of my computer. So I am certain that this is the possible cause why I cannot download .exe files. When opening in Firefox, I am receiving...
Read moreThe image below shows the kind of error that I get every time I do a right click on windows with AVI files. I have deleted all codecs and multimedia players and window media players too to make sure that there is no clash but there is no change. I have also sort the help of registry tools but with no success.
Please help me!
I am using Aegisub for arranging subtitles on my video files. Recently, when I tried to open it, I received an error stating:"ffmpegsource factory: FFmpegSource video provider: Couldn't find any video tracks: No suitable, indexed track found avisynth factory: AviSynth error: FFVideoSource: No video track found ".
I could not open my video. I tried to download the video files again and play it in Aegisub but it is still not working.
The files can be played in 001 alone, but to the rest such as 002, 003, 004, 005 etc. it is still not working.
Even if I convert it to...
Read moreI have always watched using GSL then suddenly I received a prompt text that said it needs to be updated.Unfortunately,when the update was about to be finished it failed to run the setup and I received an error report “error 0x00000071”. I tried to uninstall and later installed it again and the result was I could not be able to run the installation set up anymore! Please excuse my language because I am not a native English speaker! WTF! This is funny, it really needs to be sorted out because it is getting me depressed. I decided to install...
Read moreI have made sure that I have the most recent versions of both the power dvd ultra 7 and ultra 8.I run them under windows 7 32-bit which is the most recent as well.When I go to the Cyberlink windows 7 compatibility check the result is fine with windows 8 but it does tell me that windows 7 needs an upgrade and there appears an action of the words “coming soon”.i have tried many different disc from episode one to about four in both players without any good outcome.When trying again, I receive a prompt saying that my...
Read moreI installed Mozilla Firefox successfully on my windows 7. Later it just could not work anymore. I have tried all the available three options without any success. Does some one have any clue on what I should do? Below prompts are what I get when I try to use it.
Firefox has stopped working
Windows can check for a solution to the problem.
Check online for a solution and close the program
Close the program
Debug the program
Read moreI have installed Avast antivirus the home edition on my UBUNTU 10.04 but there is an issue with this antivirus. Every time it prompts me with an error message that reads “invalid argument”. The Avast kernel could not restart after I updated the database. If, I do not act fast this application will be ended. Kindly suggest.
Avast! Error
An Error occurred in avast! engine: invalid argument
OK
Read moreI installed ACD see 9 photo manager on my windows 7 but it is not working anymore.
The program only worked for about two days and then stopped.
I did uninstall then later installed it again but nothing changed.
Anyone with ideas on what I can do?
Read moreWhen I am trying to do a send and receive in Hotmail inbox, Outlook sync the entire box and will take 20 minutes or so before it’s over. Then when syncing again the next time, the process will not work again. When moving in to Hotmail inbox, it will take 30-60 seconds and a message will appear stating: synchronizing message headers. My Outlook is acting real slowly with my Hotmail accounts but its okay with any POP3. Can someone help?
Read moreMy current router is a Linksys WRT54GS Version 7.2 and I want to know if it is possible to connect it with my other router which is a TP Link TD W8960N and make it as my bridge router so I can have access to internet connection from first floor to the second floor of the house using a WDS. Is it possible to perform this? Does anyone have a suggestion on how to prepare this?
Thank you.
Read more
