Archive
I am using Cisco Linksys WRT100 Router. I configured it as PPPOE connection through my ISP. When I am done with the tool to establish the reaction of the DNS name services, I want to configure it manually and put it as my top DNS choice. I can set up three static IPs but I was unable to locate the configuration for turning off the automatic DNS name configuration from my provider. I run the cmd then IPCONFIG /all to check all the available connections, the listing for DNS has two DNS Name Services in advance to my three...
Read more
I am using Dlink DIR 615 router. I used to check on the router’s default address all the computers that are connected to my wireless connection. Though it is secured with password, I still want to disconnect those who I allowed to access my connection when they are not using their computer. My connection is running really slow, when I checked on the router’s IP address, I found out that the number of Dynamic DHCP Clients are more than 10 including those who are connected through their mobile phones. Is it possible to disconnect them wirelessly? If so, how...
Read more
I am customizing my Calendar in Outlook. I made some conditional formatting so I can see those meetings that I prioritized and to easily distinguish if I need to travel for a meeting. But I found out that the conditional formatting doesn’t work for most of my meetings. However, it works for other entries. What is the reason for this and how can I fix it?
Read more
One of our clients has Cisco Catalyst Express 500 (CE500). The previous administrator did not able to leave the entire login certificates. And the switch can allocate access through HTTP so there is no access in CLI. Can anyone help me on recovering the password on Cisco Catalyst Express 500 switch? Thanks.
Read more
My client is having issues opening a voicemail attachment on her inbox. She is receiving error: Cannot load objects because it is not available on this machine. I uninstalled and re-installed back Outlook for few times now and run the repair but none works so far. Can anyone help me please? Thanks for the time.
Read more
I want to install MS-Office Professional 2010 RTM (Released to Manufacturing) through Volume Licensing Service Center (VLSC) and Multiple Activation Key (MAK). I received the product .exe from a rep in Microsoft. But upon trying to insert the key, I am receiving an error that the key is not valid. What can I do? I need help.
Read more
I encountered an error when I was working with MYOB. I was trying to access some accounting files, but I cannot open them. I was also trying to back up save my files, but I get the same error from M-Powered Services Support which I inserted below. I checked files for error, but I get the same error message. Now I couldn’t do anything. Please tell me how to fix this. Thank you very much.
AccountRight Plus
Error 1006 was encountered when opening the M-Powered Services Centre data file.
Please...
Read more
I can’t install Adobe Shockwave Player to my OSX 10.6 Snow Leopard. Aren’t they compatible with each other? I have tried reinstalling it but it still failed. There must be something wrong with the Shockwave installer or its compatibility version for Mac Book. Please help me find ways to fix it. I need to take Brain Fitness test as soon as possible.
The installation failed.
The installer encountered an error that caused the
installation to fail. Contact the software manufacturer
for assistance.
Read more
After updating my Fedora 14 database, I received an Avast error message which says the engine argument is invalid.
What should be the next thing to do?
Could I just use Avast itself to fix the problem or external help is needed?
I have inserted the image of the error message below for more understanding.
Please suggest on what to do.
Error:
An error occurred in avast! engine: Invalid argument
Deleted stale lock file '/root/.avast/lockfile-root'.
Read more
I was installing the latest version of Kaspersky Internet Security to my computer. My problem is I could not activate it. An error dialog says that the number of activations using this code exceeded. I hit fix and reinstall button but it gave me the same result. How could I get a different code? Or how would I deal with problems like this?
Thanks for your help.
Number of activations using this code exceeded.
Read more
