Archive
I have already sought online help from Apple discussions, but I could not find the exact solution to my problem.
It would be very nice if I could get a response to this as soon as possible.
My Final Cut Professional 7.0 is not launching. It says it was re-launched, and it quit unexpectedly after it was re-launched.
If someone is having the same problem, please share with me your effective solutions.
The application Final Cut Pro quit unexpectedly after it was relaunched.
Mac OS x and other applications are not affected.
Click Relaunch to launch the application again. Click Report
to...
Read more
I forgot my gmail password and also forgot my recovery email. My security question is also not coming. Because my id is infiltrated. So how can I recover my email. I badly need the account.
Please, somebody help me or please access this email id from me. "t*****@gmail.com".
Please try to access to this id and give the password so that I can do my important work. Please this is an emergency.
Read more
I am having trouble with my JDownloader. It says that there is problem sending the command to the program. I am using Netgear Router DGB34G and my Firmware Version is V5.01.01. I noticed that these two routers are not listed in my JDownloader when I scroll down its connection option. Is this where the problem originated? Is this the reason why I cannot connect? Should I shift to any router listed in JDownloader to make it work?
C:Users*******DocumentsProject tracking infoProje...
There was a problem sending the command to the program
Read more
I cannot use my MSN Instant Messaging Account with Proteus.
I have been using this service called Proteus IM Application for my MacBook, but now I am having a problem with it. I could not connect my MSN account. It is saying that it’s having connection problems and tells me to try to connect later.
The message is from Proteus Service Error. Does this mean that this Mac IM application is faulty?
What option could I take in fixing this?
Personal is having connection problems
Try connecting again later.
Read more
I was just wondering why after installing MS Office to my Windows 7 64Bit Version, my Skype stopped working. There should not be any compatibility problems between Skype and MS Office right? I can still log in successfully, can still see who’s online and who’s not but an error message kept me from working ahead. I can’t click into whoever’s name and it is asking me to close the program instead. What should I do?
Skype has stopped working
A problem caused the program to stop working correctly.
Windows will close the program and notify you if...
Read more
I am trying to install the program Avid studio and I have been through more than half way of the installation process. Most of the program features have already been installed. I arrived at a certain step that when I clicked the next button, an error message appeared saying that there is an error reading a certain file called Arpeggios from the program files. It just gave me two options to retry or to cancel. Which one should I choose?
Avid Studio Installer Information
Error 1305.Error reading file C:Program Files(x86)PinnacleShared FileSoundsStageHypersonic...
Read more
Does REAPER only allow us to use a maximum of 1.5GB of RAM? An error message from Kontakt keep on saying that it could not allocate enough memory and the application is likely to become unstable.
It happened when my RAM usage exceeded 1.5GB. Can someone give me complete details about this problem? It is confusing me because I still have enough memory space in my RAM.
Kontakt 4
PANIC: Could not allocate enough memory. Application is likely to become unstable.
Read more
Please help me with my SDL Trados Studio. I cannot open my Palette CAD Project which I need to finish so badly.
I am using SDL Studio for days, but today it failed to open my 8000 Euro Project. It says there is an error in XML document which I could not figure out what. SDL Trados Studio used to work so well with my projects but suddenly, it stopped working today.
Can anyone help me please?
Failed to activate project 'PaletteCad' Failed to load project from
'C:SPRACHDIENSTLIEISTUNGENMeinradJuni 2010PaletteCADPaletteCad.sdlproj':
There is an error in XML document (15861,26).
Guid should contain 32...
Read more
What should I do if an error message is telling me that my Adobe Illustrator CS4 is not responding? This is the only Adobe application that is having a problem. The rest are working properly. Adobe Illustrator hangs up and does not respond whenever I am trying to open it.
This error occurred after upgrading my Operating System to Windows 7 64 bit. After installing Adobe CS4 Web Premium in it, all Adobe applications work well without a problem except this Adobe Illustrator. I don’t think it is not compatible with Windows 7 64Bit is it? I need some help...
Read more
I was trying to work out a document via InDesign to PDF. While I was trying to convert the data I got this error shown below. It used to work properly and I only got this error for the first time and I have nothing in mind about what is going on here. It’s the automation who sends this error message and it’s not coming from the InDesign alert. Does it have a problem with any other program connected to this? I need some help to fix my problem.
I have been using the Automator...
Read more
