Archive
My Cinema 4D has got an application error. While I am working with my Cinema 4D, this error message just suddenly appeared on the display screen. It is saying something about bug report.
The message keeps on popping up whenever I restart the program or the Cinema application. I tried to close it and open it again to see whether the message won’t appear again, but I still encountered the same error.
Please help.
CINEMA 4D
Application Error! More information can be found under
Folder path_BugReport.txt
After clicking "OK" scene files will be saved as "_bugreports/_recovert_xxx.c4d
Read moreHi there,
Can someone please tell me the difference in features between Microsoft Office 2007 Excel and Word from the previous Microsoft versions?
For instance Microsoft Office 2002 Excel and Word, could anyone distinguish those features for me?
I would really appreciate your help.
Read moreI am trying to make a backup from my old HP Pavilion computer. I need to change my entire CPU to the following specifications: 4GB DDR3, Intel Core 2 Duo, and Asus M4 Series. I was on my way to finish the backup process until I encountered some errors. The panel pins and the larger plug-in for the old motherboard was combined together so I have to take them out to plug into a smaller panel pins. But I could not locate the pint out illustration for the obsolete motherboard. So I get lost with the uses of various...
Read moreI am indistinct with Amps measurements and its use to power supplies with the conforming power cords that is plugged directly to the outlets. I owned an external hard disk that needs 12V 4.0amp adaptor. I placed a small block to control the hard disk power correctly. I have other cord that plugs with the outlet and can manage 2.5amps as specified on the tag of the wire. I want to know if this one will work on my hard disk or not. Please send me some suggestions and resolution. Thanks.
Read moreHello to all our Experts here! My brother gave me a Transcend 500GB External Hard Disk. It has 2 USB plug at the end of it. But I am only using one USB cord for data transferring. It’s been working perfectly fine for the whole time that I am using it. But when I tried to install it to my Dell Inspiron 1520 with Windows XP, it entirely made the computer system to stopped working correctly. I even press the power button to force close my computer. I tried to revert my BIOS settings to the previous month to...
Read moreI got this error message while I was making a deployment.
It has an error about accessing a file folder followed by a windows installer error.
It says that my 3DS Max Deployment creation fails with access error.
But why did it display such error when I can have total access to my folders.
I presume it has nothing to do with access rights. What could it be? I am totally confused about this.
Any suggestion would be a great help to me.
Autodesk 3ds Max Design 2010
Error 1304. Error writing to file \thewarehousegroup.netGFSBIM WhgSystemCad BuildAutodesk3dsMaxDesign2010_64ImageAdminImagemain32bitProgram FilesAutoDesk3ds Max Design...
I am very unlucky when after spending so much time in creating animated videos with my Anime Studio Pro, I suddenly received this error below that says something about failure to open files and there is a read error, image layer.cpp.
I was just so tired and exhausted that after all I have done, I got just such a failure. My project is not accessible.
Please suggest ways on how to retrieve everything. I don’t want to go back to the very beginning.
Anime Studio Pro
Could not open file
Error details:
Read error at line 81162. In code file ......lib_mohoimagelayer.cpp,...
Read moreHi,
I get this error message when I was starting an Adobe Creative Suite application. The message is pasted below. I am working with Adobe Photoshop and Adobe Illustrator every day in my office and this is the first time I have encountered this problem. It comes out when I open any Adobe application. Does this mean that I need to buy a new license again for this to work back normally? I need some help on fixing this.
Licensing for this product has stopped working.
This product has encountered a problem...
Read moreI was warned of having an unresponsive script while browsing Mozilla Firefox.
That error message above is displayed while I am running Mozilla Firefox.
It only offers two options of which to stop the script or to continue it.
Which one should I hit in order to stop this message from showing up?
What could be the source of this error?
Can someone suggest me the best solution for this problem?
Warning: Unresponsive script
A script on this page may be busy, or it may have stopped responding.
You can stop the script now, or you can continue to see if the...
Read moreI am not a pro when it comes to IT related issues. I wanted to download the weather network into my windows vista basic. I was able to download the program which includes weather eye and weather maps. The download was completed but when I tried to run the program, an error saying APPLICATION NOT FOUND comes out. I also get the same error message when checking my email inbox and any hyperlink in my system is not working. I am wondering whether anybody out there is having the same problem as mine. I presume maybe this has something...
Read more
