Archive
I get an error when trying to distribute data to my partitions. My data partition has 272GB space and my OS partition has 25GB. I am running a Windows Server 2003 small business server. I was performing commands for the redistribution of spaces when I get this dialog box below. I need to know why this happened. Any suggestion would be very useful for me because I want to finish this task in order to continue with my work. Thanks.
Partition Manager
operation failed
No free space...
Does anybody have any idea of what is going on with my Adobe Premier 9? I was editing my video and was doing some finishing touches. When I was trying to preview it, I got an error message stating: Adobe Premiere Elements.exe No Disk.
There is no disk in the drive. Please insert a disk in to drive Device Harddisk3DR3. The message will only disappear when a disk is inserted although I am not writing my video into it. I need your suggestions on resolving this. Thanks a lot.
Read moreI am running my daily Malware Anti-Malware program and had deleted some threats. My antivirus is McAfee Total Protection 2010 and my computer’s operating system is Windows Vista 32bit. After having run that antimalware, I got an error message that says “YOUR COMPUTER IS AT RISK, CHECK FOR UPDATES.” I just followed what it said so I check my computer for some updates but I found out that my system is updated.
I had tried to submit this case to online McAfee support but I could not get into their website because it is not showing on the screen. My...
Read moreI was working with Hallmark Card Studio 2011. I have updated it on the 3rd of October this year. I have been working with this program regularly but this is my first time to get an error.
I am not printing today but the error is related to the print artist program. I was trying to think of possible cause but I cannot get into a conclusion.
I am attaching the error message below in order to give further details of the error.
Print Artist Platinum
Exception thrown in destructor
(f:ddvctoolsvc7libsshipatlmfcsrcmfcviewcore.cpp:59)
Encountered an improper argument
Read moreI am not able to open my ACDSee Photo Manager.
I was about to try to remove and reinstall the program in order to fix it but I remember that I have bulks of categorized files in it which could possibly be messed up.
So I just did a system restore and Microsoft update has been installed. Now when I am trying to open ACDSee, I get the same error.
I need someone who could figure out what is wrong with my system.
Thank you.
Read moreHello, I need to fix my problem with uploading files using FileZilla. I was uploading .php files to my computer using FileZilla and an error message popped up. It says: Response: 552 Disk Full – please upload later. Error: Critical File Transfer Error. I was confused why it says that the disk is full when my control panel is showing me that my memory usage is 4MB out of 500MB. Please help me with this.
Read moreHi there, my operating system is Windows 7 and I was having this Orbit downloader for quite a while already. Now when I opened it, an error message appeared: ORBIT DOWNLOADER HAS STOPPED WORKING and it keeps showing up whenever the program is started. I get the same error message when I use GOM and Grab++. What is this problem related to? I have no idea how to fix them I need some suggestions.
Read moreHi, I’ve encountered a problem with netbeans I could not run them with my Linux. I have just shifted to Linux from Windows and I want to install Java in it. I preferred to use Java in lieu of Eclipse because I am already used to how it works and I am comfortable with it. Some features of Eclipse are not my type and I have trouble adjusting with it. Aside from that, I also could not open Eclipse so I preferred to install Java app. But I could not open .class files and .java files using Java I...
Read moreI need some help in opening my documents in which I have locked inside the Access folder which I have downloaded. I could not open them anymore when I tried to unlock them. Anybody could help me by telling me how to fix the error that says,
"THERE WAS A PROBLEM ENCOUNTERED WHEN TRYING TO UNLOCK THE FOLDER."
I was trying to keep them very safe that now I could not open them when it’s time to use them.
Any help is appreciated.
Read moreI use four main features of Outlook and these are the Calendar, Contacts, Notes (which are also called as “Memos”) and Tasks. My question is; will all of these features sync with an iPhone? I thought I heard that iPhone does not allow Notes/Memos to be sync. I even heard that maybe the Tasks part does not also sync with iPhone. If those parts do not sync with an iPhone, are there any applications that allow these parts to sync?
Read more
