Archive
I used to have an iPhone 3G but I lost it. My wife has an iPhone 3GS and she just got an iPhone 4S today so she gave me her old iPhone 3GS. About a month ago, I have a back up of my lost iPhone 3G. Since it was running in iOS 4 at the time of the back up, I cannot restore my 3G back up for the new iPhone 3GS which is currently running in iOS 5. I tried to restore my back up by downgrading my new iPhone 3GS to iOS 4 then upgrading to...
Read more
My question is will my iPhone automatically connect to my wireless home network? For example, if I have turned on the 3G connection on my iPhone while I am currently connected to my home network, will my iPhone automatically use my wireless connection at home instead of the 3G connection?
Will my iPhone automatically connects to my wireless connection at home if both my home network connection and 3G are turned on? I thought maybe I could get some help from you guys by answering my questions.
Read more
Hello all! I finished uploading my new roster to my iPad just today. I have noticed that the rest period bar located at the top left of the radar screen has vanished. Have I deleted it accidentally? Or I just haven’t set something correctly? Is it possible that it would just disappear without me deleting it? Do you have any ideas how to retrieve it?
Read more
I just bought a new iPhone.  I did a back-up on my old iPhone because I wanted to restore my files to my new one. My problem is my previous files do not transfer to my new iPhone.  I am also having trouble getting data from logten pro from my old iPhone to and transferring them to my new one. I have an up-to-date iPad. Is it possible to sync my iPad to the iPhone I have right now or will it only work the other way around?
Read more
Every time I need to use the GPS on my iPhone 3G, I need to do a network reset before it works and the GPS always stops working after about an hour. I’m not sure why the GPS on my iPhone 3G doesn’t work consistently. There was a time when I tried to use it for long hours and I noticed that the problem got even worse. A few months ago, it would occasionally go out and come back on. Now, more often than not, the GPS is off.  Does anyone know the possible causes why it keeps on...
Read more
Is there an application in Android phones that will allow me to do multitasking and kill open applications? An iPhone has this feature and I would like to know if there is an Android application that will let me kill multiple open applications at once, just like with an iPhone. Is there an Advanced Task Killer for Android phones? And also, I do not want to keep on opening an application to see how many cells I have used and how many data I have inputted. I want to know if there is a data monitoring application that can...
Read more
I happen to be working on an application that has 19 tabs that have unique graphics. Those tabs look fine in my mockups but when I imported them in Interface Builder, of course they were all flat gray. Is there a technique or script that can convert my regular colored-bitmap icons to be exactly the same as an iPhone tab graphic? Can anyone give me an automatic way to convert bitmap icons to a properly formatted iPhone tab graphic? Is there a simple Photoshop step or technique to convert these bitmap icons to iPhone tab graphics?
Read more
My question is can I switch to Verizon and get a new Android phone whenever I want?
I currently have this iPhone 3G but I really want to switch to Android phone.
I no longer like the iPhone from AT&T. Is it possible to get now the fascinating Android X?
Does it make sense or I shall wait until early 2011 to see the new dual core/LTE phones?
How long before dual core/LTE Android phones come from Verizon?
Read more
Dears,
Is it possible to open an older access database in Access 97 instead of Access 2010?
What do I do to get all column names with types alongside?
Can I combine multiple columns of different formats and query using nested IFs?
Sure you have correct answers.
Thanks in advance.
Read more
Dear experts,
How can I open .pub files using an open-source software? What are other means to have this file opened?
doug
Read more
