Archive
I have a really serious issue in installing SP6. Actually everything had been working fine since I deployed 7.4 SP6 last week. But today when everyone tried to tried to install SP6 by launching the point, they got the error saying
"This installation package could not be opened. Contact the application vendor to verify that this is a valid Windows Installer package."
I only have one way back now which is SP5. But even while installing that I got the same error. I tried many alternative ways to do that like with cached installation, without cached installation and non- cached...
Read more
I was trying to create a new Nios II Application and BSP from Template. But I couldn’t do it and faced to following error;
unable to create project
Reason: Failed to execute:./create-this-app --no-make
chmod: changing permissions of `.': Permission denied
chmod: changing permissions of `./create-this-app': Permission denied
I am using quartus2 and nios2eds on the windows at the moment. I am seeking for your nice suggestions in this matter. I would be grateful to you.
Read more
I have been trying to deploy adobe reader x for last some days but I have been receiving an error saying;The install of application "Package Name" from policy "Policy Name" failed. The error was The installation source for this product is not available. Verify that the source exists and that you can access it. I even tried so many other sources like https://support.microsoft.com/en-us/help/278472/packages-assigned-to-computers-with-group-policy-are-not-installed, to see what the problem with it is, but couldn’t find anything. I have no idea about this problem. Please let me know your suggestions in this matter. I would be grateful to you.
Read more
I have been facing an issue while installing firmware 3.50. Actually, my Ps3 required to be fixed and for that I tried to update it but when it reached at around 20% of the installation process, it showed me an error sayingerror 8002F147. I even have tried to format the disk and install the older version. Now 2 months have been passed and I couldn’t use my Ps3. Please help me out in this matter. I would be very grateful to you.
Read more
I have been facing problem in clean installing windows on my notebook.  Actually some months ago, I installed windows 7 ultimate 32-bit on it. It worked perfect at that time but after some time, it began to restart repeatedly. It was so annoying. I even tried to clean and re-install the windows but failed to do so and it shows me error saying 0x80070057 and cannot install on the partition.  I even tried disk part method to resolve the issue but again was failed in doing so. I really need your nice suggestions in the matter as I am...
Read more
I have two hard drives in my computer. Currently I am using Windows 7 Ultimate 32-Bit which is installed in C-drive via ISO. As I have two separated hard drives, I want to install Windows 7 Home Premium 64-Bit on the secondary one. Now the issue which I am facing at the moment is I don’t know how to boot it. Definitely, it won’t boot like ultimate ISO version did. I even tried to install vista on my other hard drive so that I could clean install over it but when I tried to boot it, I faced...
Read more
I have been facing an issue while using Network Access Software. I don’t know much about the error but I have attached a short screen for your considerations.
Error: Message Stl-nt-34 is not available for viewing
                   Reason : channel access denied
Please have a look on this and let me know how to resolve this issue. I would be grateful to you.
Read more
Hi Experts! I need help on Outlook 2007. All the exported contacts are not visible. I already exported all my contacts into a CSV file. I heard that one of the possible causes of this is when there are special characters included on my contacts, but I did not use any special characters so I don’t think that it is the main cause of the issue. How can I fix this? Is it possible to export Outlook contacts into a CSV file that will be visible? Please help. Thank you.
Read more
I am using a dual-boot PC with Windows XP and Windows 7. When in Windows XP, I can open all the documents without errors on Compatibility Mode. I can edit and save the documents in a normal way. But when in Windows 7, the documents can be open as Read Only Documents. I cannot edit or save any changes with it. I already unchecked the boxes in the File Block Settings in the Trust Center. Sadly, the settings for both MS-Word 2003 and MS-Word 97 binary documents and templates do not have a check box to select for saving....
Read more
I have to reinstall my Windows 7 after running software which I got from the web that caused various problems and errors on my system. When I checked on the Device Manager, I am missing some of the drivers but my task manager did not supply any information needed to distinguish the hardware. Is there any third-party software that I can use and will provide me all the information needed? Help please. Thank you.
Read more
