Archive
I use an HP Workstation x4000 in creating CAD models here at work. It is already an out-of-date computer and recently, I ran out of memory in my hard drive. It has specifications of 58 GB SCSI, 68pin HP. The IT technician who works in our company bought me a 1GB SATA Drive, Raid Card, just enough memory to load the MEC Card, and also the Norton Ghost to speed up the recent drive. But the problem is that, the card that he purchased cannot be put in the Mobo. My computer has a ribbon with an empty plug...
Read moreWhile using Medisoft advanced v17 SP2 today, it started giving me certain errors. Actually, I just upgraded it yesterday from Medisoft Advanced v16 SP1. Everything was running so fine but now when I tried to access the data, I received the following error;
tbltransaction: Field Diagnosis_9 not found and tblPatient: closed dataset
Please give me your kind suggestions to resolve this issue. I would be grateful to you.
Read moreWhat will I do first if I wanted to setup a DNS server Active Directory domain, should I install the DNS service first and name the zone ‘name.org’? Can I use the ‘name.org’ in the AD domain?
Read moreEverything is 2000 or 2003 member servers except for PDC and BDCs because these are NT, and I am upgrading it from NT to 2003.
Do I need to upgrade everything in my 2000/2003 member servers even if they are not in NT domain?
Read moreI was able to use desktop sharing when I tried the UCtrial, but when I setup the 2007 R2 Standard server and connect it to a Communicator client and when I am in the video chat already, I couldn’t find the desktop sharing button. How can I fix this problem?
Read moreThere are a lot of companies who are now using the Sharepoint and I couldn’t see any thread of devotion in the use of SP integration with OCS 2007. Is there any doc that explains this both WSS 3.0 and MOSS 2007? Particularly, we are interested in using the presence within SP which makes web conferencing possible.
Read moreDoes anyone feel fulfilled in deploying the Lotus Notes 8.5 or 8.5.1 on XenApp 4.5 or 5.0? Even though I know that the Notes were only supported on XenApp 4.5, I still don’t feel the satisfaction in our test lab. Right now I am using the Windows 2003 x86 w/SP2,XenApp 4.5 RP3.
Read moreI own an external hard disk and I want to check it for errors. Thus, I performed error checking from Properties >Tools.
I ticked the two options: “Automatically fix file system errors” and “Scan for and attempt recovery of bad sectors”.
For a while, I believed it stopped scanning so I decided to click the Cancel button and then the disk is unserviceable.
It displayed a message: “X: is not accessible. Access is denied."
I encountered that message again after I attempted to check for errors.
Kindly help me with my problem.
Read moreI delivered a XenApp 5 for Win2k3 with Office 2010 to my client. And my client had already a Lotus Notes 8.5 locally installed.
Can you please help me because when user tries to ‘Save and Send’ form the MS application the response was, “Word couldn't send mail because of MAPI failure: Unspecified Error”.
Read morePlease help me with my Lenovo K1 Idea-Pad that I purchased recently, I had trouble in downloading several apps from the android apps store. Every time I tried to download and install the Every trail, the response from the downloader was I need to update the Google maps, but I couldn’t use the Google maps every time I try to use it and I couldn’t use the Every trail also because it is not loading.
Read more
