Archive
Good Morning,
I am developing legal briefs, which contain multimedia presentations, form elements and searchable documents and it is saving on a CD. These CD’s are meant to be used by the Court. I am not a programmer or a trained designer, but just an attorney.
I have bought ‘Acrobat 7 Pro’ along with the books ‘Acrobat forms with java script’ and ‘Adobe Acrobat 7 PDF bible’. I have bought ‘DocuMate 262’ scanner and I got ‘Omnipage Pro 12’ along with it for OCR capabilities.
Are there any major changes in Acrobat 8 from Acrobat 7? So, I have to purchase ‘Adobe...
Read more
I am a regular Ubuntu OS user and I am facing a problem which I want to share with you. The problem is an error message saying
Could not update CEauthority/home/test-user/.ICEauthority’.
I used Ubuntu 9.10 before, and I have had a bitter experience from this error/message.
But then again, I attempted installing Ubuntu GNOME 3 at 11:04 Natty Narwhal but the same error occurred.
I would say that it is necessary to come up with a solution to this problem if you are planning to reinstall Ubuntu.
Please let me know what you think about this problem. And what can...
Read more
I tried to install Ubuntu 11.04 OS on my PC using a USB flash drive. I want it to remain inside my current OS, Windows XP. As it is a home PC, I am concerned whether or not the other computer users in my family would like it, which is the reason I wanted it to run inside my current OS. As per the instructions, I proceeded with the install process but the following error message interrupted it:
 “Cannot download the metalink and therefore the ISO”.
 Please check the screenshots for details and let me know how to...
Read more
In order to convert tons of mathematics and physics documents to PDF for my students, I have purchased ‘Omnipage 17 Pro’.
I am facing a problem which is, ‘Omnipage’ is not showing most of the symbols in the documents.
When I want to edit those symbols, it is making me mad.
All documents are having lot of symbols and it will take a lot of time to edit.
So I am looking for help to add character set in ‘Omnipage’, when the symbols are not available in the default character set.
Please help me to get out of this problem.
Thanks in advance for all...
Read more
I am currently using Windows 7. I downloaded Ubuntu 2.5 and want to install it on my current OS. The installation process initiates when I start Wubi but suddenly stops showing me this prompt: “Could not retrieve the required installation files.”
A file (debug) named ‘wubi-9.10ubuntu1-rev160’ appears in the message which is located on my computer’s ‘temp’ folder.
Please see attached picture to give you an idea.
Hope you can solve it for me. I’ll be waiting for your feedback.
Error Message:
Assistant damorcage sur CD Ubuntu
Une erreur est survenue:
Read more
Ubuntu Intrepic 8.10 is my operating system and I am having trouble with my gnome panel.
As I click the right mouse button at the top of the gnome panel and then go to properties, the attached message pops-up saying “The folder contents could not be displayed.
Error stating file ‘/tmp/evince-6347’: No such file or directory”.
If I close the error message, the properties window shows ‘Some of these properties are locked down.’
Do you have any suggestions as it is quite troublesome for me.
Read more
I have recently installed Google Chrome on my PC, but unfortunately the program terminates every time I try to run it. It gives me an Application error prompt. I have not faced this kind of problem before.
chrome.exe - Application error
The application failed to initialize properly (0xc0000005). Click on OK to terminate the application.
Please help me out on this.
Read more
Hi there,
When a game was trying to be installed on Quad-core new PC and an error message appeared right after. The error message screenshot was attached here your reference.  I tried to reboot the machine many times, the settings were not changed, and Windows Defender was not enabled.  However, same error message appeared again and again.
I realized after some research on the internet that Windows Vista McAfee Security 2009 would disable MS Windows Defender. I suspected that McAfee Security automatically disabled Windows Defender option to enhance the system general performance while the newly installed game might enabled Windows...
Read more
I worked with Mac OS X Leopard before until I tried upgrading it to Fusion version 1.1. However, after completing the upgrade process, my operating system suddenly failed to operate.
It prompted the message: ‘The application failed to initialize properly (0x0000005). Click on Ok to terminate the application’. Has any one encountered this error? I need your help on this.
Error Message:
aspnet_regiis.exe - Application Error
The application failed to intialize property (0xc0000005). Click on OK to terminate the application.
Read more
I have recently installed ‘SmartQ V5 Android 2.1 MOD’ firmware on my SmartQ Android device.
After successfully installing the firmware, an error message popped-up (See attached screenshot). Unfortunately, I cannot download the firmware from the Android website. And also, I tried flashing my Android’s ROM three times, but still, the same result. Do you have any suggestions for this case?
I would appreciate your feedback on this, it will save me a lot of trouble.
Sorry!
The process com.google.process.gapps has stopped unexpectedly. Please try again.
Read more
