Archive
Guyz,
Can you tell me where a Brazilian ‘abnt2’ keyboard layout for my vostro will be available ? I have tried but was not successful finding any information.
Looking forward,
Mark
Read more
What is the purpose in designing A/C? What was the agreement with this character? Is it usable to choose one of the designs in A/C to multiple wage standards? How about the supervising of the distant? And where should I refer?
Read more
Hi dudes,
Everything was working fine after the vanilla installation of Snow Leo in Vostro 1520. But I am facing a problem. The Wi-Fi was not working at first and I have installed BCM43XX enabler and also executed the command at the terminal. After that I have restarted the system and the internet was working properly.
The problem is when I switch off the computer, internet is getting disconnected. So I restarted the computer but internet did not work. The wireless connection I getting connected but internet connection is not available and the browser says there is no internet connection. When...
Read more
What are the differences in terms of usage between the Lightweight Data Interchange Format, Data Exchange (LDIFDE) and Comma Separated Value Data Exchange (CSVDE)?
And also, what are the roles of the Flexible Single Master Operation (FSMO)?
Which of them is creating an error?
What would be the effects if one of them failed?
Read more
Hi Gurus,
I was installing Peachtree Accounting 2010 System when I got this error message (see screenshot below).
Peachtree Accounting 2012 - InstallShield Wizard
Peachtree requires a minimum operating system of Windows XP SP2 or Windows Vista SP1.
The installation will now close.
I wondered why this happened when I have Win XP SP 2 installed.
Any advice on how to fix the problem?
Do I need to do the tedious task of reinstalling Win XP?
Please help me and provide a workaround solution.
Thanks in advance.
Read more
What will you do if you changed the server into DC, and you are assigned to locate the remote with slow WAN link? And it could be effective to remove AD from a server and what would you do afterwards?
Read more
Is it possible to set up a new Windows 2003 Domain Controller on a Windows 2000 Active Directory? I need to know on how to set up a new Windows Server 2003 R2 on a Windows 2003 AD DC. And what was the requisition on setting up an AD to a new server?
Read more
Can I access Active Directory (AD) services to other third-party software? Where does the AD database located? What are those same folders which is similar to AD? And how can I copy the properties for AD distribution and DC?
Read more
Techyv,
I am facing problems in iPhone 4 Wi-Fi. It is working but I have to turn off and again turn it on. It is saying that it is already connected with the router but there is no internet connectivity.   I have to reset the WiFi by turning it  off and turning it on.
It is happening all the time, when I am closing the phone and when  using it the next time. Previously I was using iPhone 3G and it was working properly with the router. I have tried resetting the router and also changed the settings to factory settings,...
Read more
Is there any limitation on Windows Server 2003 that doesn't exist in recent products? How many passwords to be recalled when you are checking the "Enforce Password History Remembered"?
Read more
