Archive
I have upgraded my video card to Diamond Viper 770 Ultra.
It has different jumper configurations for AGP 2x and 4x.
I have an Intel Pentium 440BX chipset mx 400mhx.
From which of the following will I set it, is it by 2x or 4x AGP?
Read moreHow can we transfer the location of save folders in OS default drive? For example in "My Documents", is it the same with Outlook Express, Tools> Options> Maintenance> Store Folder> Store Location? Please help.
Read moreWhy don’t we use a Structured Query Language (SQL) or queries from X to Resource Description Framework (RDF) files query? Why does it need to enhance new query of words? And how fast could I work on the task item into the emails?
Read moreI'm having a problem on converting the notes that I received. I notice that there are some messages have an apostrophes and quotations. How can I fix it?
Read moreDears,
There is a little red ball badge in the firmware of Apple V. 5.0.1 since the release of the update. I am aware that it is showing because, I did not update the application and I don’t want to update the same.
I am looking for help to remove the red badge without updating the application. Please help me get rid of this.
Randy
Read moreTechies,
I am not able to play all video and audio files in the KM player. I have chosen ‘XINE’ engine for KM player. When I am trying to play new file, there is a message showing in the bottom of KM Player which says ‘Ready’, but nothing is happening in the window.
I have changed the engine for KM player to ‘Media Player’. After this I am getting the message that ‘media player is buffering’ in the main window when I am playing a new file. The same is happening with KAFFEINE when selecting the XINE engine and playing new...
Read moreHey there,
Here's my issue. I had to recover lost data from iPhone 3G, which was not backed up. I have created image of the iPhone which comes around 8 GB. I have used the Photorec to parse the image and it looked like it finished the work. But I have faced a problem with that.
All contacts seem to be in the ‘vcard’ format but it has the extension of ‘.abcdp’. When I am trying to open the same in text editor, it did not open. I have tried with the tutorial but there was no use. Please help me...
Read moreHello to all the tech brains out there! I am sure you can help me with this.
The bitnami VM VMDK file is converted to VHD by using the tool VMDK 2 VHD. The networking is not possible with this because bitnami VM is not having Hyper – V enlightened network. It can be started with bitnami VM with Hyper – V.
I got the following instructions in the MSDN blog, under virtual PC guy to execute ‘Ubuntu server’ by enabling the Hyper – V networking and I followed the above instruction but still networking was not available.
So, I am looking...
Read moreHi,
I have upgraded Mac OS to Mac X 10.7.2. The problem is ‘Anime Studio’ gets crashed all the time. When I am making a small movement to the character, that means importing the character as image and then separate the pieces as psd file and then try and control the influence of the bones on the images, then it forces to quit. There is no progress.
Before the up gradation of the OS everything was working fine. It is really annoying.
Please let me know if anybody had the same problem? And also give me the solution if you can at...
Read moreHi Experts,
I was testing and generating a Crystal Report in our Peachtree Accounting System when I got this error message.
Crystal Reports for Peachtree
Error detected by database DLL.
I wasn’t sure what it meant. I went to this forum since I tried the Sage forum and couldn’t find any answer.
Any expert who can help me solve the error?
Read more
