Archive
Hi friends,
I am creating lot of frame sequences for an animated character, by using Anime Studio and it will be used somewhere. So I am having lot of actions. I want to perform such actions from command line but presently I am able to do if from the main line.
Can I specify the actions through command line? Please let me know if I can add a key frame for all bones of specified bone layer, at the same time on a specified frame. Because I have to put ‘stop’ frame between the sequences on the mainline to block them...
Read more
Dudes,
I am looking for help to install Oracle 10 G on Windows 7. I have downloaded the 10.2.0.3 version but I cannot install it because an error is occurring.
‘Checking operating system requirements.
Expected result is one from 5.0, 5.1, 5.2, 6.0. Actual Result is 6.1.
Checking completed.
So the result is failed.
Oracle database 10 G does not have certificate on this OS. Recommendation – Please confirm you are installing the application on the correct platform. Service pack checking result is not executed.
Windows Vista V 6.1 is not supported. Please install the recommended service pack. Physical memory expectation is 256 MB and result...
Read more
I got this warning or error message (please see below) while installing a new version of Peachtree Accounting System.
I knew I had removed the old version and wondered why this happened.
Should I continue the process?
I was a bit scared since I was new to this thing.
Need your answer ASAP.
Thanks in advance.
Peachtree Accounting 2012 Setup
Another version of Peachtree is installed in this program location. Do you want to overwrite the previous version?
Clicking Yes not affect your company data files.
Read more
I wonder if I can set up MS Office on my system that is already configured. And then have it on my database which I made in 2003. I do not need to overrule the existing Office 2010. I need advices on how could I make it? Thank you.
Read more
I need to organize my entire list of Organization into a group separately. Are there any possible solutions? How could I make automatically means by scheduled conference section?
Read more
How should I know if a linked account has included a cycle in it and, at what node does the cycle starts? And how will you switch the double contact account? Can anyone help?
Read more
Hello Geeks,
My system configurations are specified below.
ATI Radeom 5870 1 GB
Processor : AMD Phenom II X4 Black Edition 3.2 GHz.
RAM : 4 GB
Operating System : Windows 7 - 64 bit
Screen Resolution : 1920 x 1080
I know it is not the best computer in the world but I am only able to get 20 – 30 fps when in city and 50-60 fps in the wilderness. It is causing problems to me as the fps is changing and I denied playing it.
What will be the advantage for updating the driver?  Is it 12.1? Will it improve the performance? I also...
Read more
I'm trying to boot my Dell computer, but a pop up message appears stating that the Norton Anti-Virus (NAV) Auto-Protect "cannot locate the set up data". When I tried to boot into safe mode, I'm getting the same message. Anyone have a solution for this?
Read more
We were still using an old version of Peachtree Accounting System 2009 in our office.
A fairly new user randomly got this error message when processing the payroll (see below).
The payroll formula **SIT contains the word ENTER that is not recognized by Peachtree. To see a list of possible solutions, click Help.
Actually, he just had his laptop installed with the system using Win XP.
He clicked the button Help, but couldn’t comprehend much.
Is there a way to resolve the issue?
Please help.
Read more
I set up Tomcat 5.0 as an unprivileged user in IBM AIX [not Linux]. I need to use SSL port 443, and get an error when transferred to port 8443. In Linux, you can use IP tables, what are the solutions in AIX?
Read more
