Archive
I would appreciate if someone would help me get into BIOS and how it could auto detect the new SATA internal drive I am adding to the motherboard of my PC. Not everything is going according to plan for I am unable to get into BIOS for the moment. During startup I am made aware that I should use the TAB key but on doing so windows continues to boot normally. Since then I have tried various other buttons to no avail.
Read more
I am looking for some input regarding this matter in Excel 2003. My spreadsheet has the same formula in all cell of a particular column by the use of row and indirect functions. It is using almost six thousand rows. Presently, I have to copy the formula to each cell. I think this is increasing the calculation processing time of Excel. Will it possible to assign a formula for a given column? By this I can give one formula for whole columns and this can reduce the calculation time. Please help me.
Read more
I have a HP Touch smart tx2 1120 that runs on vista 32 and has a big problem. When you attempt to boot it everything seems well as all lights come on, including both the caps lock and number lock but in the screen nothing is displayed. I have been unable to figure out why this is happening. I don’t think that my laptops oldness (it is almost three years old) is to blame for this. Someone please assist.
Read more
We would like to migrate from Exchange 2003 to Exchange 2007. I know the retention policy works different in these two versions. It is to be required and reminded to those who are having custom folders in the inbox, so we can inform them to move the custom folders one level up to work the retention policy properly.
Any utility or tool available to determine who are having custom folders? Or can the Exchange Management Shell 2007 be used for this? I need valuable assistance to get out this problem.
Thanks in advance.
Read more
I have a Pentium 4 3.00 GHz Prescott CPU which a rating of 450W on its power supply. This CPU has a problem wherein its temperature reading sometimes goes beyond the normal operating temperatures. This usually occurs when after starting the computer you load a game such as Call of Duty and the temperature rises from a previous reading of 55C to 76C. The heat sinks in the CPU are the default heat sinks that came with the machine.
Should I replace them or is this temperature increase due to a fault of the power supply? Please help, I need...
Read more
Hi, I am having an issue with my iPhone’s battery. The problem is that the battery does not charge fully to 100% even with the Wi-Fi turned off. Before, I could charge it to 100% with the Wi-Fi off but I don’t get what is wrong with it nowadays. I am unsure whether it has something to do with Wi-Fi at all or even the iCloud backup. Please help me solve this problem.
Read more
There is a certain problem I am experiencing with my iPhone which I am hoping that you can help. I installed a new update that ended up deleting all other data in my phone and on trying to restore the data I did not get any success. The phone hang even before reaching halfway of the process and giving it time did not work at all. Does anyone have an idea how to restore the data?
Read more
What are the maintenance required in mailbox databases?
The database size is 200 GB and the disk space is filling up very quickly. Usually we are doing offline defrag and consistency check of the databases in the time period of six to nine months. But because of the huge size of the database it is not easy to do this. Enterprise Vault is used for archiving the e-mails.
The free disk space is fifteen GB and we have ran offline defrag.
It gave us twenty GB free space from two storage where we had done the offline defrag.
The archiving policy changed to...
Read more
Can someone please help me figure out these problems I am experiencing since I upgraded to IOS version 5.0.1?  First, the battery runs out very fast than before and second the screen keeps shaking when y
Read more
At our workplace we have a network with less than ten computers and run an Exchange 2003 server.  We are however running into problems whenever a client logs off because the server stops running. This has taken place a number of times and each time the whole network freezes and fails to recover. I went and did some few changes which include logging USERENV 1058 and 1030. I have also made a few corrections in the registry but these actions seem to worsen the situation as the whole network collapsed. This situation has got out of hand and I...
Read more
