Archive
I am encountering a problem with a printer after moving it from the Marketing OU to Research OU. The Marketing OU is still the local administrator and can remove print jobs. What can we do to correct this?
Read morePlease help me with things that I should be familiar with on Enterprise Linux OS aside from the general LAMP. I would like to be proficient in this software and I am looking at managing Linux systems in the near future.
Read moreI need help on why it does not show 100% CPU usage, but the LXDE monitor reflects 100%. I have installed Ubuntu on my Linux laptop because I am experiencing soft lockups. However, after turning my laptop on, it is still slow and freezes for several seconds.
Read moreI used TurboLaw Software and while I am trying to make a new document, I got the same exact error on the images below. Both errors occurred on MS-Word and Excel when accessing new documents. The error states TurboLaw could not start MS Word or Excel to display my document. Please help. I need to use this software ASAP.
Error Starting Microsoft Excel
TurboLaw could not start Microsoft Excel to display your document. The error was: Retrieving the COM class factory for component with CLSID {00024500-0000-0000-C000-000000000046} failed due to the following error:...
Read morePlease help us in determining our LDAP connection string.
We would like to test an active directory membership provider.
We know our domain, and we are on a corporate network.
Read moreI have been stuck on the part, ‘Defeat The Enemy Sniper part of Call of Duty 5’ for several days while on board the Vendetta, how do I beat it?
Read moreWhen Citrix is downloaded on Mac, there in an error message indicating that ‘error-7-local security certificate cannot be downloaded’. I got it to work after updated Java was installed, but the error occurred again.
Explain what the issue here would be.
Read more
I tried to connect to the internet using a Nintendo WiFi USB adapter, but it gives an error as well as wireless connection with the router.
Why is WiFi not connected to internet?
Read moreExplain how cache memory can be used in mobile computing. Can someone retrieve information from the cache memory of someone else’s computer?
Read moreThere is no internet connectivity with the modem and router together, however, eliminating the router and just using the modem works fine. There doesn’t seem to be a power issue with the router.
What could the problem be?
Read more
