Archive
I have Sony Vegas pro8 and edited it. When I put an effect on my Sony Vegas pro.8, it works apart from box of the screen.
How do I fix it?
Read more
I am having problem on trying to refurnish a cineform.mov file from Adobe After Effects CS5.5.
I got an error from After Effects similar to the screenshot below.
I am really lost right now.
I can do the render option in other cineform files with After Effects CS4 and Adobe Premiere CS5; I am stuck with this error right now.
I hope someone can help me with this puzzling issue I encounter when trying to render a Cineform Quicktime file from After Effects CS5. I get a file may be corrupt message when attempting to render from After Effects. But the strange thing...
Read more
Hi
Explain whether movies can be put on iTunes or a disc, in order to watch them on computer later without taking up space on the computer and, not necessarily a DVD to play them?
Read more
Explain whether movies can be put on iTunes or a disk, in order to watch them on computer later without taking up a space on the computer and, not necessarily a DVD to play them?
Read more
hi
When I put my avatar episodes into timeline it just shows the audio as they are all offline and I cannot trim them though I like to make AMVs. Why these avatar episodes are offline?
Read more
 I would like to purchase a new computer with Windows 7 and MS – Office 2007. Presently I am using Windows XP and Office 2000. My Outlook 2000 ‘.pst’ file size is two GB and it gives some problem in Outlook 2000. I want to know whether the Outlook 2007 supports my Outlook 2000 file. Please help me to solve the issue. Please help me to get out this problem. Thanks in advance.
Read more
I have developed a macro in Excel which will prompt to enter 2 cell numbers. My plan is that it will display a message box which shows the cell numbers entered by the user. But the message box is showing ‘TRUE’ instead of the cell number entered by the user. Please give me the solution.
Read more
hi
 I have created certain forms using Microsoft Office InfoPath 2010 and organized this on the IIS sever. When I open the server, the list of files open. On clicking the form, I get the option to select the program with which the file needs to be opened. How do I set browser as the default program to open the file every time I click on it? Is it possible?
Read more
Where can I get NVIDIA optimus Graphics card for notebook? Is it possible to upgrade Alienware M15x laptop with its own graphics card to NVIDIA GT450?
Read more
 Whether a software installation on a 64-bit system with Vista uses 32-bit or 64-bit computation?
Read more
