Archive
I am creating a PowerPoint presentation. I need to insert a thought bubble and automatically add multiple photos in it. Can anyone explain me the procedure? I also need help in changing the size of the pen and text marker tool in PowerPoint.
Please help.
Read moreI have a Mac computer with Windows installed on multiple monitor setup. How do I make the Windows operating system confine to only one monitor? Also, I would like to setup the “Home” and “End” functions on a Mac keyboard as that in every Windows keyboard. How can it be done? And also I need assistance in cleaning a Mac Mini combo drive.
Read moreHi
I am unable to install Adobe Flash Player on my computer. Is there any other version or similar software that is compatible with my 64-bit Windows Vista computer?
Read moreI would like to know if the release of Apple Lossless Audio Codec resources under Apache license will pay way for the development of new IOS platform
Read moreHow do Adobe Air functions in saving the state of an offline flash game on a local computer? Can anyone help me?
Read moreCan you suggest any specific tool or application that can be used for developing Adobe AIR application runtime? And please state the difference between AIR and AJAX and web browser? And also please name the operating systems that are compatible with Adobe AIR.
Read more
When I am working with a site and clicked on the other link outside the homepage, I keep getting an alert from my antivirus software that says I have an infected Real Time file.
How can it be fix?
I can’t seem to open eBahn® Reader Software on my Windows Vista PC. I keep getting “Unable to open” message. What is the cause for this? Any help?
C:Program FiIeseBahneBahn.exe
Executable C:Program FileseBahneBahn.exe had the following unrecoverable
error:
unable to open
OK
I am getting error “You are attempting to install over a previous installation of Quartus II software (includes IP Library), ModelSim-Altera Starter Edition (Free). You must either uninstall the previous installation or choose a new installation directory before continuing with this installation.” I already removed Quartus II Web Edition Software but I am still having this error. How can I fix it?
I have Mini-Stream Ripper installed on my Windows XP Pro computer. I am running out of space so I want to remove those applications that I don’t usually use. I’ve been trying to delete this one, but I was unable to.
I am using the uninstaller that comes with the software package. The icon was removed from my desktop, but the entire folders that are connected with Mini-Stream Ripper are still appearing on the Program Files folder. I keep getting
Access is denied error when attempting to delete this.
Please help me.
Error Deleting File or Folder
Cannot...
