Archive
H! Guys.
I am an apple product fan and with the recent release of the iphone, i enjoy all its feature and design..But i never tried the blackberry, i would like to ask if it also have a facetime like that on apple?
Read more
An error from Virgin Media Security’s Firewall appeared from my computer. The error is “The following program is attempting to connect to the Internet or the network.” “Do you want to allow access?” with Allow, Allow once and Block options in the bottom of the window. I hit the Block button because the application that appears is located on my personal files which I don’t normally use except when needed. When I tried to search for the file on my computer, I could not locate it even when I changed the hidden folders to become visible. I scanned my...
Read more
Hello! I just want to ask some questions regarding the issue I am facing right now.
My computer at work has an issue running the software used by our company.
The personal IT of the company told me that he will remove everything from my computer and will make it work like new.
He told me to save and backup everything important and just leave or delete those that are not needed anymore.
I want to know now, which one should I save?
I have some software which I purchased so I don't know if I can restore it if he will wipe everything...
Read more
Every time I use open my internet server, this error always appear. It really takes time to back into track and my net is getting slow. Is this a VIRUS or something wrong with my computer?
How can I overcome this error?.
Plug-in Unresponsive
The following plug-in is unresponsive: Unknown Would you like to stop it?
Read more
I need to install Belkin Power UPS Management Software on my Windows XP PC, but every time I tried, this message is showing:
Error Message:
Repeatedly Running
There is an instance of setup running, please exit.
OK
What does it mean? I only run the installation once.
Help me on this please.
Read more
There is one more year before my license in Avira gets expired and according to them, I can upgrade without purchasing or won’t cost me any. So I upgraded to Avira 2012. I successfully installed it on my Windows 7 PC. And I was eager to run the scan because I want to know what the changes in this recent edition are. But I cannot make it work. I cannot even upgrade anymore because of this error “avcenter.exe –
Bad Image” that keeps popping up. What is the solution for this?
avcenter.exe - Bad Image
C:WindowsWinSxSx86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_41e6975e2bd6f2b2COM...
Read more
I have McAfee Security-as-a-Service installed on my 10 Windows Vista PCs. Lately, I cannot update it either automatic or manual updating. It cannot even work and run on a normal state. I cannot do anything with it.
All I can see is a “Runtime Error” that keeps showing. I am thinking that this is a server settings problem.
The error is shown below.
Please help.
Error:
Server Err in '/MC/VS521'Application.Runtime Error Description:An application error occurred on the server the details of the application error from being viewed(for security reason).It could however,be viewed by browsers running on the local server...
Read more
I am facing issues with StackTack jQuery plug-in. StackTack is used to tack Q&A from StackExchange websites.  I am using this with a more elevated blogger template. But it needs to update the style sheet.
And since, I don’t have much time to perform everything; I just changed it to the default template. Since then, the question is not showing on Internet Explorer 8. StackTack does not display the question and gives me this error message:
Error:
Windows Internet Explorer
"Errors on this webpage might cause it to work incorrectly."
To see this message in...
Read more
Hi Guys Need Wordpress help,
I want show some pages at right side but when i add page widget then ( home, about us etc ) are also added these are pages at top. I don't want show these pages at right side i want some new pages at right side and i want those pages ( at top ) don't appear at right side and those pages that appear at right side don't appear at top. If anyone know its solution please tell me.
Thanks
Read more
Hi. I have a problem running my recently downloaded software from Texas Instruments. The software is called LearningCheck™ Creator Software. It was working well during the first try but now it seems to have issues with Java as the error is stating “java.lang.NullPointerException.” with Stack Trace below the error message. I am running this on my Windows 7 PC. I hope someone here can explain to me the cause and the solutions for this issue. Thank you.
Error:
Stack Trace:
java.awt.Dimension.<init?(Unknown Source)                                                     javax.swing.plaf.basic.BasicProgressBarUI.getPreferredSize(Unknown Source)                                                      javax.swing.IComponent.getPreferredSize(Unknown Source)                       com.ti.nav.sdk.view.NavAppJFrame$StatusBar.<init>(NavAppJFrame.java:596)  com.ti.nav.sdk.view.NavAppJFrame$StatusBar.<init>(NavAppJFrame.java:597) com.ti.nav.sdk.view.NavAppJFrame.<init>(NavAppJFrame.java:502)                 com.t.eps.cat.app.AplicationMain.<init>(AplicationMain.java:247)                         sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)    sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown...
Read more
