Archive
I upgraded my Mac PC to OS X Snow Leopard 10.6 which I think is the most possible reason why I am getting a licensing error on opening my entire Adobe products.
I have Adobe CS4 which I used primarily for business.
It was working well before the upgrade but now it just stops working as an error keeps showing when I tried to access it.
The error message is shown below:
Error Message:
Licensing for this product has stopped working.
This product has encountered a problem which requires that you restart your computer before it can be launched. If you...
Read more
I am trying to create a new database and start the Upsizing Wizard as I need to upsize my database to SQL Server 2005.
But a Server Error 1803: CREATE DATABASE failed. Primary file must be at least 3MB to accommodate a copy of the model database. appeared on doing it.
What is the cause of this and how to resolve this?
The error message is shown below.
Any help will do.
Read more
Since I am a cloud partner I had the ability of joining the beta which I did. There is an extra tab at the top of the O365 beta which enables me to gain access to partner specific features for I know I have other partners. This tab would have been used to send trials to our clients and should they wish to convert, they would have a link to our trial account. Currently I think partners have two different accounts, one being the O365 beta/trial account and the other one which is meant for BPOS partner benefits subscriptions....
Read more
I am sure you are aware that migration from BPOS will commence three to four months after GA release. Majority of us are in the beta which expire in about a month so I am wondering whether Cloud partners with BPOS be migrated earlier in order for us to be able to continue testing and demonstrating O365 to our customers?
I would be grateful if someone can please give me an answer to this concern?
Read more
why do we have problems logging in to Skype from different computers apart from the one we used to open the account?Sometimes, I find it hard to open my account from different computers.Might it be that an IP address of a computer is recorded with a unique sign-up in Skype that causes it not to open when another person with different ID try to access his account? This has been a persistent problem that I need help.
Read more
I am wondering if there is something wrong with my computer since the  CPU usage meter that I have activated on my screen is displaying a value of 49% down from 55% with all the non – Microsoft  services disabled. Does anyone know what might be causing this drop? Please help.
Read more
Can someone please tell me which features of Microsoft can be disabled without bringing about negative effects on the performance of your computer? The last time I disabled some Microsoft services, I was unable to access the internet services and also the display properties acted strange. I want to avoid this again.
I need an expert’s help.
Thanks
Read more
At my workplace we have three computers; one of them is a Toshiba and the other two are Dell and Sony respectively. Both the Sony and Dell computers are running on Windows 7 while the Toshiba runs on Windows Vista. Each computer has a document file located in the library and all the files have green folders. There is a Manila folder that is named Documents which also has a green folder that is saved as documents. The Manila folder is found under documents. The Toshiba, on Vista OS, is giving me a rough time with these folders. When...
Read more
I have a computer that is running on Windows 7 and it has a problem that I am unable to do away with. I started a particular game and then closed it. But the weird thing is that even after rebooting it, the computer thinks that the game is still running. I don’t understand this. I have tried several things but none of it has solved the problem. I am now desperate for your help.
Read more
Hi, I am looking for someone to give me an informed opinion on cloud computing for high performance computing applications. What does the future hold for it? The applications I am referring to are the scientific software that usually uses a high processing power. Will there be changes to the alternatives of the programs that are currently on use such as Cyclone, which is not that interesting to use. Thanks in advance for your help
Read more
