Archive
There is something weird going on with my computer and I can’t find the cause. The problem is that I hear sounds like ads or even radio conversations even if there are no programs running. I have scanned my computer for Malware and Adware but didn’t find any, it’s clean. Can somebody please give me a solution to this? Thanks.
Read moreI am currently using a UNIX server and I am wondering whether memory will be allocated for each individual code, data and stack in the process if I start several copies of the same process? I shall be grateful for any answer offered.
Read more
I've encountered this error when I try to setup remote connection of my daylight server on a separate location I already configured router and setup port forwarding by the way this is on Mac Machines. The ISP already provided me with a static IP on both sites but still connection failed. Any help please. I capture the error screen shots that will be easier for you to understand this error.
My objective here is to make the two mac machine see each other as like the vpn (virtual private network).
Error:
Database search failed because the...
Read moreI experience this error several times already. I log in with my correct yahoo email address and correct password but still I can't access my account. Is this normal or something wrong with my installation process?. How can I overcome this issue not to happen again?
Sign-In Problem There was a problem signing into Yahoo! Please try again a little bit later. (81003005) |
Read more
I have some questions related to MOSS 3.0, not on WSS (windows share point).
- What field(s) does SPS list use to identify an email as part of an existing thread?
- Is it possible to create a new email and somehow tag it, so that it attaches to a specific thread (and does not create a new thread)?
- Is there a way to configure SPS via a list workflow to attach an email to a thread if it contains a specific string in an email subject?
We have a ticket tracking system which assigns 9 unique digit numbers. What do you think? Is it...
Read moreMy file is on a network drive and every time I try to open a *.pst file I get this message: “Errors have been detected in the file z:MyFile.pst”.
Its file size is 2,856,729 KB.
Then, when I attempt to change the time and date stamp on the file it still cannot open.
Any ideas and suggestions?
Read moreHow can I send email to a mobile phone via SMS using Outlook Mobile services without encountering problems? When I send emails to mobile phones with Outlook, the message body, the most important part, is missing on the text that my recipients receive and the other information was sent instantly.
Read moreI’ve done remote session with PowerShell and gathered admin credentials and made remote session to an Exchange machine passing along the acquired credential.
Then I’m done in implicitly removing. Now, every item I gathered will clearly be the kind of "Deserialized".
Can anyone share an idea on how to access and obtain a couple of feature of remote exchange server through Powershell?
Could I load the kind of data used by Exchange and be able to access all the members of this object?
Read more
Both my outlook and OCS are 2007 and running in Windows server 2008r2. Why can’t I save OCS conversations in the outlook conversation history folder as this option is disabled in OCS. And also, I cannot view outlook properties from OCS.
Can anyone advise me with this issue?
Read moreI have a client who likes to transfer 30 user accounts that presently uses Calendar into several Public Folders.
What will I do in order to export the calendar into a PST file from Outlook 2003, and then I could create a Public Folder (Calendar) and provide the necessary permissions to it?
Afterwards, I could import the calendar into this new public folder location.
Any relevant suggestions or advice will be greatly appreciated.
Read more
