Archive
How can be used ‘MAthGL’ with the ‘FORTRAN’. I am having a class and drawing method Foo and draw ‘mglGraph*. How can we use the FLTK / GLUT window? I need to know how to avoid a point or region of plot in the drawing.
Read moreThe program is receiving a SEGV signal with the debugger and I am not sure why this is happening. What is the chance of having a problem with VTALARM, fork or threads? Also getting error messages like, ‘X’ Library is not founding. What is the meaning of missing ‘RTHooks’? What is the reason for exception rising by the ‘X’ / Network Object application?
Read moreExplain about Modula 3 and what are the uses and where will it be available? Can it be useful to industry? Commercial support is available or not? Where will be available the documents and more information about Modula 3? What is the advantage of Modula 3 as compared to Modula 2?
Read moreCan someone please explain what Modula 2 is?
Where are Modula 2 compilers available?
Where will the source code be available?
Are there any questions available about code and algorithms?
Is there any reference material of Modula 2?
Read moreI need help to direct the linker into different ‘mpi’ library with ‘PGHPF’. Also need to create link map with the compilers. The linker is complaining regarding the missing symbol ‘ctype_b’.
Read morePlease help me fix the error ‘un defined reference to f – xargc’. Also the underscore problem is to be solved. How can I say the linker for ignoring the unresolved reference? The MKL with PGI compiler can be used and if can be used how can it be used?
Read moreI need help to convert rotation matrix to quaternion. The computation of the covariance of image projection, can be done in which method. Can be the bundle adjustment more efficient by using the MEX file? Is SBA can be used in commercial application?
Read moreIs anything required to use 'sba'? I got a link error for unresolved external symbol and I have no idea why it is happening. I would like to adapt ‘sba’ to BA variant. I have given reconstruction to sba as starting point and how it is to be computed. Any idea about sba robust to outlying data?
Read moreWhere I can search the details regarding the programming in ‘CULA’? Also need to find ‘functions reference’. What are the tools may used for making the ‘CULA’? I don’t know why the CULA functions are taking pointers to host memory. It was supposed to take GPU memory. Why this CULA interface seems different from all other CPU implementations?
Read moreI would like to optimize the library after the installation.
How I can make a link with ‘ATLAS’ library?
How can I avoid the object files?
What are the ‘LAPACK’ routines used by ‘ATLAS’?
Read more
