Archive
Whenever I try opening any program my screen displays the following error: “The application of DLL C:Windowssystem32winmm.dll is not a valid windows image. Please check this against your installation diskette.”  How come I can still open the programs but they would not work? Please help. Thank you.
Read more
I am trying to remove AVG LinkScanner in my Windows Vista PC, but I was unable to.
I have AVG 9.0 before and it was already removed but this AVG LinkScanner is still installed and I could not find a way to delete it.
Can someone help?
It just keeps on prompting for a reboot so I want it out of my Vista PC.
It has setup error with code 0xC0070643 with Additional message, Driver installation failed (0x00000000).
I am trying to uninstall and not to re-install.
What is causing this?
Help please.
AVG LinkScanner® Software Installer
AVG
LinkS canner
Setup error
Severity: Error
Error code: 0xC0070643
Error message: General...
Read more
I am having a problem configuring the new computers at my workplace which are running on Windows 7 Pro x64. I would like to have these connect to the print server using the pushprinterconnections.exe, with the printers mapped through group policy. Adding the 64-bit driver for the Xerox phase did not help.
The other PCs running on WinXP x32 do not have the same problems and are functioning well. I am wondering if I have to create a new printer and also an AD container and policy in the Print Management. Clearly I am missing something. Hope you can help.
Read more
Can anybody please help? I am trying to run update on public folder Exchange 2010 to New-Exchange2010 but I don’t know how to do it.
Read more
I am having trouble with my Exchange 2003 server. It is currently being set up with a new ISP. For now we are able to only receive mail, but can’t send any out. Whenever I telnet to the mail server from outside I receive the 220 message report “Servername.Domain” instead of the usual “mail.domain.com”. I have tried configuring this entry in the Systems Manager to no avail. Kindly help me, I am running out of ideas.
Read more
I encountered a pop-up window informing me that my computer was infected and it would “help” in removing the malware.  I rushed to download it without thinking twice.  I now regret this as I ended up having a severely infected PC with spyware.  What is the best way to remove the spyware without having to reformat my PC?And how do I avoid this in the future?What anti-spyware would you recommend?Thanks
Read more
I just started using Dynamics CRM 2011. In fact, I just installed it today. When I attempt to open MS Dynamics CRM Deployment Manager, I received an error  “Unable to obtain DNS hostname of Active Directory domain controller with ntdsa object name.” followed by some exception stack trace.
When I close the error box above, I got another error telling me that “MMC has detected an error in a snap in and will unload it.” It has two options to choose to. The first one is to report the error to Microsoft and the second one...
Read more
Is there a more efficient way of backing up data without having to undergo the tedious process of transferring the data to my external HD then to one computer then to another computer?  Is there a way to link the two computers so that data transfer is easier?  One PC has WinXP and the other has Win Vista.  Please help because I have limited knowledge on data transfer.
Read more
I am trying to run Outlook out-of-office assistant when I got this error from Microsoft Office Outlook stating “The connection to Microsoft Exchange is unavailable.
The outlook must be online or connected to complete this action.” I don’t know what is causing this but as far as I remember I also got this message when configuring my computer remotely. I wanted to use all Outlooks’ features that can help me while I am away from my computer.
Can you please help me with this?
Read more
Can anyone share an idea on how to access and obtain a couple of feature of remote exchange server through PowerShell?
I’ve done remote session with PowerShell and gathered admin credentials and made remote session to an Exchange machine passing along the acquired credential. Then I’m done in implicitly removing. Now, every item I gathered will clearly be the kind of "Deserialized".
Is there anyone who can share their ideas how I can load the kind of data used by Exchange so I will be able to access all the members of this object?
Read more
