Archive
I am new to Linux and am still familiarizing with it.
I am working with shell and I don’t understand what the load average of top implies.
There are three different values that top delivers with the load average that I don’t also understand.
The load value on my server is mostly 0, 85.
I am hoping someone can help me understand what the normal values for the load are, their significance, and how to use the data correctly.
Read more
I installed the latest windows 7 trial thinking I could create more folders. After the installation it works great but, for now, my entire system is crawling. Even the resizing of my windows takes time. Is there anything else that I should do before I decide to uninstall this latest trial?
Read more
Before I built the production server, I have created a dev server. It is still running and mobile access to this server works fine. But after I setup Windows Server 2k3 SBS, I received an error while I am connecting to OMA via windows mobile phone. There appears an error code of “0x85010014”. Also the communication that checks the domainusername says “FAILED”. Lastly there appears “HTTP 500: Forms-based auth is not enabled”. Can you tell me why it this happening?
Read more
In Windows XP3, MS Office is already included in the pack.
But when I installed a Windows 7 in my computer I found out that it doesn't have a Microsoft Office.
Is it natural?
Do I really have to download a separate MS Office software for Windows 7?
Read more
Can you tell me why after I installed SP2 and one of my users go to the website of OWA, it cannot be browsed with Internet Explorer (IE)? When using other known browsers there is no problem. But when they use the IE, they get a certificate error. Do I need something to configure in IE's settings? If yes, can you tell me what it is?
Read more
Does anybody here have any idea on which Linux distribution is best suited for a server that is mainly used as a webserver using light HTTPD software?  I am new to Linux OS and would appreciate some insights.  Thanks.
Read more
We are having problems with our repository.  We are receiving errors such as “Change set X does not exist in the repository.”  This just happened recently and we haven’t encountered this problem before.  I have deleted the repository, reinstalled it and tried to initialize and start fresh.  Even after doing all this I still get an internal server error in the web client stating that I should check the server log file.  I am considering spinning the repository then pushing it to a central server to make it accessible to users on my team.  Do I have to copy...
Read more
I visited a website through Internet Explorer 7 when an error suddenly appears.
I know that this is a common JavaScript error but I need to open the website for my project.
Can anyone please re-direct me to proper solutions?
I have been searching for similar issue as mine, but I am seeing same errors on webpage that works incorrectly but have different value for the error.
Please help.
I really need this to work.
Windows Internet Explorer
Errors on this webpage might cause it to work incorrectly
To see this image in the future, double click the warning icon on the status...
Read more
What does this mean: “Uninstall cannot be continued” and “Mailbox Database 1375826892”? The mailbox database contains of arbitration, one or more mailboxes. I’m running my Exchange 2010 server that created an environment to Exchange 2003 servers. How could I completely uninstall Exchange 2010 and avoid errors during uninstallation?
Read more
When I upload my websites to the hosting website that could make my website accessible to the world wide web,
I get some errors.
I am unable to login when using the same credential codes php/mysql that I always use to test my scripts out.
I log it in to my database using a local host.
I think that I need some IP address so that I could replace it.
But I have absolutely no idea on how to fix this problem.
Can you give me some advise?
Read more
