Archive
I need a little clarification on website URLs. If a search is done to find my website, let’s say www.mysite.com, when they find mysite, are they view it as, www.mysite.com/Default.aspx? Is it possible then for me to replace “Default.aspx” with words that relate more to my site? For example: www.mysite.com/makeup.aspx so that the page content, meta data and URL relating to makeup will be cached by google.
Please confirm if this is possible. Thanks.
Read moreI acquired a DVD multi-format recorder (brand is Memorex) which was also supposed to be able to print LightScribe labels. It came with a Nero Essentials 7 software. The problem is when copying, it will not copy the entire DVD, only portions of it. There is no message of an error. Also, after copying DVD, I attempted to create a label using LightScribe.
After creating a label and I looked in “Preview” then clicked “'Print LightScribe Label.” After a few seconds a message came out saying “Printing Successful.” I took the DVD out but it had no label. Can you...
Read moreMy computer seems to have crashed, and I don’t know why.
This the status of my computer right now:
- There are no icons appearing on my desktop.
- When I look at “All Programs”, only Adobe is visible.
- Task manager cannot be opened.
- On right clicking the desktop, nothing happens.
- Under “Program Manager” I can see some programs listed but cannot open them.
- Internet explorer icon is not available
My Outlook Express is giving me problems. Initially, I began having problems deleting emails from my Sent box. It continued to spread to all emails. Now I cannot delete any email. I tried “file” then “delete” with the same result of the email not being deleted. I can empty the deleted items folder which now does not have anything in it.
I can’t send emails I want to delete to the deleted items folder though. If I try to drag the emails to the deleted items folder, it doesn’t move and a message comes up with “error has occurred.” How...
Read moreMy company has 50 employees working away from the office. They synchronize with our database daily and we have had no problems until two days ago. Now, whenever they synchronize, this error message appears in the record log:
ERROR : [-10052] The authenticate_user script returned 4000. I reviewed previous records and learned that it should “return 1000.” I am not sure what to do as I started work here only two days ago when the problem started. The employee I replaced left two days ago. Please advise me what to do and what is causing this error to appear. Thank...
Read moreMy smart phone is unable to connect to my WiFi. I using the Bob Lite WiFi. I’m wondering if the WiFi “sleeps” like a computer when not in use for some time? When I try to connect my smart phone with the WiFi, the smart phone appears to be trying to establish a connections then ultimately disconnects. There is no error log so I cannot check what the problem is exactly. What can I do other than reboot my WiFi? Thanks.
Read moreWhy is it that most WDS studies that has been done in the recent past indicates that most android phones are more prone to hardware faults compared to other phones in the market?
Read moreWhat features distinguishes Windows XP from Window 7 and what are some of the similarities they both share in common?
Read moreI have been having a recurring error with Toast Titanium. Almost every time I burn a DVD, somewhere during the burning process, it fails with this error. Can anyone tell me what might be causing this?
Thanks in advance.
The drive reported an error:
Sense Key = ILLEGAL REQUEST
Sense Code = 0x30, 0x05
CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT
After downloading a theme from an online site m.zedge.net on Nokia N75, it does not switch on after it goes off. The phone keeps displaying a message "phone start up failed contact retailer". What is the best way to solve this problem?
Read more
