Archive
My Outlook 2007 freezes for 30 seconds to 2 minutes every 10 minutes or so. The Outlook 2007 is attached to an Exchange server. I do not see a reason for my Outlook 2007 to keep on freezing every so often and I find it very annoying. It happens when it is being used and also when it is minimized.
If it freezes while it is minimized, the window cannot be restored. When entering a message on Outlook, the window suddenly freezes up and would not accept entry for a few minutes, then what has been entered appears all of...
Read more
Hi Experts,
Configure exchange server 2010 to use iPHONE
I need to give access to 50 iPHONE users in my company to use iPHONE to access office emails
Can i get the steps
thank you
Read more
What are the features of websense? What are the best parts of it How are they different from ISA server?
Thanks in advance Raghunath seshadri
Read more
It is often a question which software performs best? and at one point why when you are too familiar with windows 2007, you find it difficult to run office 2010?
Read more
Windows Installer Error 1620
This installation package could not be opened. Contact the application vendor to verify that this is a valid Windows Installer package.
How can i fix this error
Read more
I have a query regarding the proper installation of the Bluetooth device for my Nokia 6233 cell phone. It used to work fine on Windows XP. But now, in Windows 7, it does not install correctly. It gives the error 'Bluetooth Peripheral Device doesn't have a driver' whenever I troubleshoot it from the 'Devices and Printers > Bluetooth Devices' menu. Windows searches for the driver but is unable to find it online. I have even installed Nokia PC Suite in the hope that it would solve the problem.
Troubleshooting has completed
Troubleshooting was unable to automatically fix all...
Read more
A link was created between MySQL and MSSQL wherein we can replicate the database from MySQL once (the first time) but subsequently receive this error message: Executed as user: NT AUTHORITYNETWORK SERVICE. An object, “access right” can already be found in the database.
Executing it gets this error: [SQLSTATE 42S01] (Error 2714). Can you tell me how we can let MSSQL to write over the existing tables? Thank you.
Read more
My two routers are connected by a bridge and I would like to determine what devices access our network using the two routers. I am searching how to perform network mapping.
Basically, we need a single sign on, for users to connect to our intranet when they are in the office and connect through a virtual private network where they will be able to view the intranet.
The problem is if accessing the intranet outside the office, users need to enter their active directory user name and password to validate their access via lightweight directory access protocol (LDAP) because authentication falls...
Read more
I am using a 500GB Western Digital USB 3.0 Hard Drive with Windows 8 installed on it. It is running on several computers and is working perfectly until yesterday. On start up, it shows the Win8 Boot screen but proceeds to show a blue screen and an error message: "0xC000021A".
I attempted to display Win8 Boot loader using the Options menu but get the same error message. This is common for all-in-one computers and have not yet seen it on a laptop. What could be the problem?
Read more
I have a Windows 7 Enterprise on my computer. and I am using a boot virtual hard disk which works perfectly. I have to execute several commands prior to booting the virtual hard disk.
What is the best way to boot a virtual hard disk. Can I modify the boot loader? The virtual hard disk must be copied before it will boot up, then I can boot/start it. Is it possible to run a read-only virtual hard disk to automatically record outputs needed into a temporary partition?
Read more
