Archive
Hi!
I just have a question about Microsoft Exchange 2010 Server. You see, I installed four Microsoft Exchange 2010 servers for testing purposes and I also implemented high available database (DAG). The first Exchange server is dedicated to hub transport, mailbox, and client access functions; the second Exchange server is dedicated to mailbox functions; the third Exchange server is dedicated to EDGE; and the fourth Exchange server is dedicated to Transport Dumpster and File Share Witness.
The configuration seems to be working just fine. In fact, the replication between Mailbox 1 and Mailbox 2 is correct. I have tried shutting the...
Read moreI need help in downloading java. A notification error would appear stating that Internet explorer could not show the webpage. When I try to bring my java up to date in the control panel, a notification error would then appear stating that the update for java can’t proceed due to the internet connection currently set in the system.
It asks me to check the Internet Options in the Control Panel and verify whether the settings are correct. It also asks me to verify whether the proxy information is correct. What should I do?
Read moreI have a problem and it has become a real hassle. It happens whenever I switch on my PC. Two minutes after, the Windows 7 would revert back to the Windows Basic. At that time, I could not go back to windows 7. After an average of 5 minutes, it would switch back to normal.
This always happens whenever I log in, especially during the time when I am from hibernation.
Read moreI am in HTML mode and currently using an Outlook 2003 in Win7 but every time I’m trying to send an excel for a user of a MAC they’ll always get an winmail1dat.file which is if you will email in a rich text format but I am not using that. In every plain text that I’ve send they’ll get an .xls and to my friend using Mac he gets the same .xls file too. What could you say about this? Is this fine? Or not?
And can you give me some suggestions on how could I send the xls.file in...
Read moreWhy is that my computer is shutting down after my friend installed the Windows 7? I have my Antec 650w True Power supply. And I’m always making an monitor to the watts and they’re all stable. And the temperatures are all fine. Does the RAM that I bought is the reason why my computer is shutting down? For now, I am recently getting an HD4850.
Read moreI’m having a problem of removing the single retaining clip from the heatsink from my computer which runs through the centre of the unit. I already tried to remove it using a screwdriver while pushing and pulling it down but still the single clip couldn’t release. And my last choice is I want to remove my motherboard but if I do that, I'll probably have to but a new heatsink unit complete with a retaining clip.
I need your advices and suggestions about this. So that I could install my Athlon XP 2400 just to upgrade an older motherboard with...
Read moreCan you give me some methods on how could I keep from being the first and only person that gets locked off the network? Because I shared a network with some several users. And there are different machines that could access my network regularly. Those are the:
Ø 2 Mac book pros
Ø 2 laptops
Ø 1 Mac book
Ø 1 desktop
Ø 1 XBOX 360 that runs live
Ø 3 iPods
Every time I m using the network I can’t connect easily due to some persons connects to my internet. And I want that I would be the First that could connect the internet easily...
Read more
Can you help me about this please? My D-Link WDA 2320 Range booster Desktop Adapter has no connectivity for a couple days ago I already configure the IP but still it has no effect. I reset my primary ISP modem and Linksys WRT300N wireless router.
It still does not work. I think that my Desktop Adapter is the problem because my iPod and Play station 3 still work while it connects to my wireless router. I already try the IP configurations. Do you have any suggestions?
Read more
What can be used to find an MS Outlook .pst file on a machine and define which profile is it associated with? I am using Windows XP and Outlook ’03.
Read moreHi All,
Is another web server needed to sync Outlook with CRM live? How are they integrated physically? Thanks in advance.
Read more
