Archive
Is there a difference between MS Outlook and Outlook Express? If there is, how do you convert data from Outlook to Express and vice versa?
Read moreHow can an Excel spreadsheet be converted to an Access database? Also, how can an Access form be converted to a spreadsheet through the form as front for data capture? Can several users be linked to a database to allow data to flow into the database?
Read moreI have been searching everywhere for solutions, but it seems that I am the only person encountering the same error.
My problem is, each time I am trying to connect to iChat, it gives me this error “Could not connect to Jabber.
An unexpected SSL error occurred. [-9843] 08:28 am."
My connection is firm, and I am sure of that because I can connect for about 15 seconds and then this error will appear.
How can I fix this?
Hi All,
How to open multiple links at once in Firefox and Chrome
I have seen these add-on's on a clients Pc and was wondering where and how to install it.?
So can open many URL's in one shot.
Thank you
Read moreI’ve been trying to print wireless to my Lexmark Z2400 wireless printer that connects to my Windows7 computer via USB cable. I have my Windows computer set for sharing to my newly purchased Mac Book Pro OS X. But I have no idea if what should I need to do just to get it print wirelessly to the printer.
Could I just share them? Or should they be network?
What solutions that you could suggest and the steps that should I take?
Read moreI want to reformat the hard drive and install a more recent operating system like Ubuntu to my Apple Power G4.But I found out that my notebook would not turn on I already tried to charge the battery for good 4 hours but it doesn’t giving a response.
Does the adapter is shot or the battery itself shot? Here’s my UFO/yo-yo style model adapter: M7332/ SR# 1191804177.What could you recommend about this? Do I need to replace the old battery?
And can you give me some suggestions if what is the cheapest battery because I just only have a limited budget.
Read moreWindows XP is installed in my drive C. I downloaded Windows 8 and installed it to drive D for a test drive. Unfortunately after the installation, I could not boot back with Windows XP. I ran it with repair setup and was able to boot XP again, but now I could not run Windows 8. How will I be able to boot my pc with dual-OS?
Please help.
Read moreI borrowed an MS Office CD and it can only be used in a limited number of devices, including my laptop. But I had to delete everything from my laptop. If I reinstall Office using the borrowed CD, will it regard my laptop as a different device or will it know that it is the same one?
Read moreHow do you hide system tables from programs like MS Access? Everytime I link tables in our SQL database, other system views are included in the list and I cannot find which tables I need asap.
Read moreI don’t have any more advanced security features that could prefer to our sites would be implemented from my Wi-Fi G routers. Do I need to replace the old-routers with a newer on that could run the Wi-Fi with already a new security protocols? Or should I say does it worth upgrading by refreshing their ROMs with DD-WRT?
Read more
