Archive
I am trying to install MS Office using a customer MST file which is
"MaintWiz.exe /c "\SMSSERVERe$PackagesOffice 2003Office 2003 UpgradeFullInstall.CMW" /qb-"
This command works fine with CMD but if I run it through SMS, an error shows stating the reason why it will not run. The message is somehow saying that System Management Server (SMS) can determine the status for every program it executes.
If SMS could not find the status of installation for the program with the Management Information Format (MIF) files, an exit code is then used to determine the status. But then, the exit code -2147467259 does not work...
Read moreI cannot open Excel 2003 attachments. But if I save it first, I can open it. This only happens with Excel files. What’s wrong?
Read moreHow do you specify a range for a report from SQL Server Report Services to be exported to MS Excel? The range should have a name and refers to some cells with certain columns for the rows that are rendered for table control.
Read moreIs there a way to export 400k rows in MS Access ’07 to Excel?
I want the row restriction of 65k to change to 1M in Access.
Read moreIs it possible to make several e-mails with the same subject and message but sent to different addresses with different attachments?
Please give me step by step method
Read moreHow can I use and share a document from my main PC to an XP virtual machine?
I have a VM on my desktop. Between these 2 how can i transfer files?
Read moreHow can a word file be locked so that no one will be allowed to view and edit the file?
Can we also lock other MS Office files?
Read moreHi Experts,
When we save documents in Word and Excel 2007, they would automatically zip.
How do we prevent this?
Thanks in advance
Read moreHow do you bring about records from a table? I want to use a query which has words entered in a textbox. It only works if the specific word/s is/are entered in the criteria in the design view.
Read moreHow do you expand the partition size in Windows XP?
What if you delete the backup partition, and then you want to use the free space to add to the main partition, is it possible?
Read more
