Archive
I have Windows XP.
The moment it’s running and I’m at the desktop with no programs opened, what must I do create a partition using disk administrator?
Read more
What would be the best way to back up an Exchange server into a tape drive? Will NTbackup be enough?
Read more
Can we use shadow copy to back up copies that are off site on a Windows server? If yes, where are they stored? Can they be copied manually and is it possible to restore from them? Will it be a security issue?
Read more
What is the purpose of SIP proxy server and how will it affect us if it is down? Can it be run virtually and have a backup?
Read more
I used Ease US Partition Manager Software on managing my partition C and D. I cut down the size of my Drive D and increased the other partition drive. When I click on Apply, I got error message “2 operations are currently pending. Apply changes now?” I click the YES button and then my computer restarted.
Upon loading, the process for cutting down the size of my Drive D started. Afterwards I got an error “There is not enough free space on the operating partition to move/resize. Press any key to reboot. ” When I click to reboot, the same...
Read more
Hello. I'm running Mac OS X Snow Leopard. My problem is regarding cuteFTP on Mac that I am receiving when I am trying to launch cuteFTP. The error CuteFTP Mac quit unexpectedly."
I am unable to continue since clicking the Reopen button below will just prompt me to the same window and same error message.
Can someone please help me?
Click Reopen to open the application again. Click report to see more detailed information and send a report to Apple.
Read more
Hi there,
I'm having issues with my Google Music Manager Application. When I try to install it, I end up with an error which says that only two accounts can be used per computer, and that I have already used two accounts previously to sign in to Music Manager. Here is the actual error text:
Only two accounts can be used per computer.
Two accounts were previously used to sign in to the Music Manager on this computer. Only two Google accounts can be used per computer with Music Manager.
I am quite confident that this the first time that I tried to...
Read more
Hello!
I am facing an error in Adobe Photoshop CS4 Extended as I am trying to customize the image quality and while doing some filtering.
The error is stating “Owl Orphanage - photoshop.exe Entry Point Not found.” When using Photoshop CS3 Extended, everything is working well. But going back to my dilemma, the error just keeps appearing.
Please send some help. Thank you guys.
Owl Orphanage: Photoshop.exe - Entry Point Not Found
The process entry point ?Decode.Tile JP2KImage@@QAE4333333@Z could not be located in the dynamic link library 3P2K1.dll
Read more
I have been getting this faulty message ‘An error was encountered while indexing. Another program may be locking X1’s files.
The database has been cleared, and indexing has been stopped. Restart it to try one more time.
If the problem recurs, try closing other programs until indexing is complete.’ I am using X1 Version 6.2.2 on Windows 7 PC.
It was unable to repair an index even if I leave it as the only application running.
I don’t use any backup software, and I also scanned my PC for viruses.
Error
Read more
I got an error ‘Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately. Root element is missing.’ while playing Fable 3 on my Windows Vista PC. It seems like an error in my Java but I don’t have any idea on how it can be solved. What root element is missing and how I can restore it? When I click on Continue button the error, I can continue with the game. When I click on the Quit button,...
Read more
