Archive
Hello there! I need some help on creating a second email account which will be accessible for users and connect it in MS Outlook. What would be the most effective ideas to perform this in a huge corporation? Do I need to create a mailbox or make a user profile for each address? I would like a support from any search engines and use MS Exchange hosting. And also, I want to put only those authorized accounts to ensure that all the messages from their second accounts will also go directly to user’s inbox on their primary accounts. I...
Read moreI own an external hard disk and I want to check it for errors. Thus, I performed error checking from Properties>Tools. I ticked the two options: “Automatically fix file system errors” and “Scan for and attempt recovery of bad sectors”. For a while, I believed it stopped scanning so I decided to click the Cancel button and then the disk is unserviceable.
It displayed a message: “X: is not accessible. Access is denied." I encountered that message again after I attempted to check for errors. Kindly help me with my problem.
Read morehelp i need to be able to delete and move emails from my inbox as am getting error message no disk space
Read moreHello,
I keep getting trashed messages on my Yahoo Mail coming from someone that is using my contact’s addresses pretending to be the sender. I was thinking, what I needed to generally worry about is really happening as of now. I actually did some checking and modified my security password into my Yahoo profile. I want to know if this is a virus or someone is trying to access my account unauthorized. How can I get rid of it?
Read more
Hi Experts,
Yahoo mail Vs Google Mail
Which is better email service. What are the best suggestions you experts can give.
Thank you
Which is the best among Mozy, Box.net and Dropbox?
How did the change of pricing models affect your usage?
Is the encryption and customer service important?
Read moreHow will you know if Node 1 has failed to work and few resources, like Disk and SQL, were not transferred from Node 1 to Node 2? Thanks in advance!
Read moreEverytime someone will send a calendar invite for a specific user using the Outlook 2010 Pro, the Outlook Exchange 2003 server will send an NDR saying that the message cannot be sent to a user who is no longer in the company. We checked the list of delegates and there were no entries. Any kind of help will be appreciated.
Read moreI left my laptop on last night when I went to bed. When I woke up, I checked on my laptop and I was shocked to see on the screen that Windows will not start, instead it's either I will run the Repair Setup of Windows or start it normally. I chose the repair setup but it got stacked up in loading.
The HDD light is on portraying that it is running. I attempted to run windows normally but same thing happened; it was stacked in loading screen. So I tried running it in a Safe Mode, Windows loads for...
Read moreI have set up a free edition of MS Office 2007 Specialist. Can I be able to change it into a full edition by applying a product key or should Igo for the new set up? Kindly send me some suggestions.
Read more
