Archive
Hi All,
Windows 7 does not show run as administrator. This is a MSI file and does not show the option.
How can i run as admin. Is there any alternative way?
Thanks
Read moreHi IT,
Hello. Is there someone here who knows how to install BlackBerry Tablet OS SDK to Adobe AIR?
I am trying to install it but only ends up with an error “Incorrect SDK Detected Incorrect AIR SDK selected.
The error is also stating that I need a Version 2.5 of Adobe AIR to continue and directed me to the site where I can download it.
So I went to the given site and found this:
The only version that is available for download is Adobe AIR 2.0.2.
Does someone here know where I can download the required version?
I found in other...
Read moreFor the previous days, I've been receiving faulty information that says "Error 777: The connection attempt failed because the modem (or other connecting device) on the remote computer is out of order." I am connected to the internet. I have Huawei Access Manager and it is connected to the internet since I am using Tata Photon which is also from Huawei. This problem mostly occurred during night time. As I am trying to connect again, the same error message just keeps on popping up. What can I do with it?
My server is Server 2008 R2 box which runs as KMS server as well. It has 35 clients who are using MS Office 2010. I used the customization tool to create an installer package so as to activate it through KMS. However, my clients could not activate the program. I can forcibly activate it though ospp.vbs and set the host of KMS, just that it would be nicer if my clients can automatically activate it using KMS. What do I have to do?
Read moreI was properly setting up the MS Office 2010+ in SP1 using the command 'setup.exe /adminfile "OSD.msp"' in an Open Software Description.
Since SP1 is already phased out, I looked for a way on how I could update the Office 2010+ and I have read that I can extract it from "officesuite2010sp1-kb2460049-x86-fullfile-en-us.exe" then have it put in the updates folder.
But this command file does not seem to work. The MS Office+ is still in my programs but there were no updates installed. Does someone have an experience like this? What should I do with this?
Read more
I set the default settings of the Font in One Note 2007. I did this through the Tools Menu, then selected the Options, then the Editing tab, and clicked on Default Font; thinking that will set its default settings.
I use this font for note titles, however, the font for body text always go back to Calibri even if I try to change it and use other font styles. I have tried setting it into a default font but when I use bullets, numbering, or even just in a new paragraph, it goes back to Calibri. How will I change...
Read moreWhen is the best time to defragment a hardly-used hard drive on a Windows Server 2003? This is a file server which has files that are written and deleted for many times in a week and is accessed by around 25 users. Is there an alert when the hard fragmentation is reached?
Read moreEverytime we run a D/R recovery from stand alone 820 to LPAY 870 an error says the OS keys are invalid. How do we eliminate this issue?
Read moreOur 2008 AD network runs 200 Windows 7 machines and I’m wondering, which maintenance tasks are appropriate for these machines? Disk scan, defragment, etc.?
Read more
