Archive
Hi All, Can we clone production ERP boxes with the configuration and drives?
Regards Chandra
Read moreIs it possible to duplicate a database server and its content and then transfer to a virtual machine? We wish to do it with servers that are on expensive machines.
Read moreIs it possible to lock the records after the updates in Access database? I also would like the interface to show only a certain form for the user to fill out.
Read moreHow do you remove SQL injections and guard against them? My antivirus detected one. Now my computer runs slow so I want to know what went wrong.
Read moreCan AD 2003 domain users use their credentials to log on to Windows 2003 FTP servers? Is there a way to have a single login so there is no need to authenticate every connection?
Read moreI am running my computer with various issues and as I searched for a no-cost program application that can help me utilize and fix those issues, I installed Avast Free Antivirus.
When installed successfully, an error “Unsecured. Your System is not protected. Please use the Fix Now button start protecting your system. Urgent: Avast Service stopped. The Avast Antivirus program has been stopped or is in an inconsistent state.
Please re-start the program to resume protecting your system.” appeared on it. Why is it that I am still unsecured when I have already downloaded Avast properly?
Please help.
My operating system is Windows 7 x64 with Skype 4.2. It was working well for the past months of using the two.
But when I started my Skype today, I got an error that say something about authorizations.
I tried to re-install Skype but only received another error message stating
Information
Installing Skype failed; code 1638.
Another version of this product is already installed. Installation of this Version cannot continue. To configure or remove the existing version of this product, use Add/Remove Programs in Control Panel.
I searched on my computer’s application lists and some other options for another version of Skype that is installed...
Read moreAs I am enjoying my WMV 11 or movie/x-microsoft-WMV, an error “A Security problem occurred.” appears on my Windows XP computer. This appears on the page through Gamer Advertising Online page. How can I resolve it?
While trying to set up ancient video games like Dave I received this problem: "D:FLASHG~1DAVE.exe
The NTVD CPU has encountered an illegal instruction. CS:c000 IP:5b9a OP:0f 00 00 00 03 Choose ‘Close’ to terminate the application.
I can't start my .bat C++ gathered applications; as I attempt to press on the .bat, it posted a dark-colored CMD screen and runs.
I have scanned my PC using ESET antivirus 4 and Malware bytes but no threats have been found. I am running Windows XP.
Please help me.
Read moreI have set up MediaMonkey 4 and applied all the contents of my old MediaMonkey 3 file source for improving mm4. While working with the record, I got an error “There was a problem querying the database: Could not retrieve data “SELECT IDSong FROM PlaylistSongs WHERE IdPlaylist=2251 AND ADSong in (4536)” : database disk image is malformed (11, 11)” How can I fix this?
