Archive
Hi Experts! Could you please help me in working out for the method on using BT in two computers?
I attempt to exchange my databases from one PC to another, but I received an error “There was a problem restoring a backup file: C:UsersgarryDocumentsBlackthorneBackupsbtdatabackupsql003bak.
The current database may be in use, you may need to restart the program before attempting to restore it.” when opening database on other computer where the database is created.
I can see that it is working even if I got an error, but I am thinking that it might break my database in the future.
I am running...
Read moreHi friends. Few days back, I started to receive issue when trying to download files from Google Docs with OffiSync. The error is stating “Error occurred while downloading files from Google Docs. ERROR: An error has occurred with Google Docs service. Please try again later.” This won’t even work on my laptop or desktop PC. I also tried to accomplish it with MS Excel 2007 and 2010. Can someone please help me?
Read moreMy dilemma is regarding my GOM Media Player. I am trying to start the player, but it is not responding. It was working well for the past weeks but now it keeps giving me error
Cannot play this media file. Error code: 0x00000051
- Confirm location path of the media file.
- This media file is possible to be not supportable or to be damaged.
- Confirm that appropriate codec is initialized to play this media file.
The file that I am trying to play is an old file which runs well without issues before.
How can I fix it?
I am trying to install BearShare software from the web but I keep getting this error message as shown below:
Downloading of Installation Data from the web has failed.
Please make sure you are connected to the internet.
Would you like to:
Try to resume the broken download?
Download a new copy of data instead?
If you choose Cancel, setup will exit.
However, you will be able to resume your download from where it left off when you re-run the setup.
I recently installed VistaMizer 4.1.0.0 that works very fine.
The only problem is every time I start my computer, I am receiving errors “ACU.exe illegal system DLL relocation” “The system DLL user32.dll was relocated in memory. The application will not run properly.
I am also receiving this in SKYTEL.exe.
What is causing these and how do I resolve it?
Read moreHello everyone, I am having issues with Act 2011 and Outlook 2010 in Windows 7 x64 PC. Through the beginning of MS Outlook, it displays information stating “The ACT! Address Book service is not properly configured, or the configured database is locked. Do you want to configure it now?” If I click on “Yes”, it will open Outlook Address Books. If I clicked on “No”, it will close the application. What should I do next?
ACT! Address Book
The ACT! Address Book service is not properly configured, or the configured database is locked Do you...
I have set up Adobe Photoshop CS5 Quality. As I attempt to get started In Layout CS5, I received this error: "Configuration error. Please uninstall and reinstall the product. Error: 5” I tried to uninstall and reinstall CS5 Quality but I could not make it work. I tried calling for Adobe technical support but their ideas are not so helpful. If anyone has the same experience, how can I fix this?
Configuration error
Pease uninstall and reinstall the product.
If this problem still occurs, please contact Adobe technical support for help, and mention the...
I have set up RocketDock these days and used this for transferring most of my desktop computer data and files through it. While I got the dock installation, I placed my shortcuts among the files within the dock to ensure I might have the ability to recover my desktop computer to the authentic condition if evolved my thoughts about working with RocketDock.
The file which I saved in my computer details also had a lot of significant data, files, records, and applications which I have gathered in the recent 36 months for having my notebook computer. As of today, I...
Read moreHello,
It is my very first time to post in this message board and I think this could be my final destination as I am unable to determine this problem which I am obtaining. My problem is regarding QuarkXPress Edition: 8.16.2 as well as the error that I constantly get once I start running it.
I got this error "QuarkXpress quit unexpectedly." On my new i7 iMac 27” with OS X Snow Leopard 10.6.4. At first, before I used to add a couple of print styles in my archives after losing the "metaplus" typeface collection, almost everything is functioning great. The...
Read moreHi Experts,
Please help me on my problem, i am using Windows XP Pro computer. I am facing a problem with that sometimes I am getting an error message. The error message is like that ‘Fatal System error. The Windows Login stopped working.’ Then it is to be restarted by pressing the reset button. Please help me to fix this issue.
Thanks in advance.
Read more
