Archive
Hi!
If you have experienced this, maybe you could help me. I recently purchased a laptop which had Starter edition for Word and Excel. However, in the start menu and when I choose MS Office, a pop-up appears saying that I have to buy an activation key or enter an activation key. If I enter this key, would I automatically access the features on MS Professional Plus or would I still need to install by using the disks that came with the package? I would really appreciate your input.
Read more
Livestation application for iPhone is an application for streaming. I was trying to install it but I was unable to continue since it could not be confirmed. The DEV Livestation staff launched the program to 50 beta writers. To become one of them, I am in a rush to get and set up. However I was confused by the problem concept: "The application “Livestation” was not installed on the iPhone “arvin’s iPhone” because it could not be verified."
I actually attempted everything to acquire it. I updated my Apple iPhone to 2.2...
Read more
My Gimp is working fine yesterday so I tried to re-install it on my Windows Vista PC.
But today, as I started it, it is not working correctly. The error that I am receiving says libglib-2.0-0.dll was not found.
I tried to reinstall the program again but only get the same exact message.
How can I fix it?
gimp-2.6.exe - Unable To Locate Component
This application has failed to start because libglib-2.0-0.dll was not found. Re-installing the application may fix this problem.
OK
Read more
I am working with an application known as Cam Facilities. I can be able to record movie but my attempt to record a sound, I got a humming noise. When hitting the record sound from audio system option, I got a faulty message that says: “WaveoutGetSelect control (failed)." Anyone had an idea?
Read more
I need to upload a .png file on my laptop using Photoshop. However, I keep on receiving faulty message indicating "The procedure is not able to finish because of the unfamiliar fault. “ I cannot even identify the root of this error message. So I am seeking for help here. Thanks.
Read more
Using Macintosh as I am trying to start Jaws PDF Creator through the Command Section, I receive this problem concept: “The application Jaws PDF Creator could not be opened because "NNMoreFilesLib" could not be found.” How to resolve it?
Read more
I am trying to run Ulead Video Studio 11 by creating a film as I need to transform the Ulead data to a film document.
But I got an error when I am in 50% of the process.
The error is shown below:
Ulead VideoStudio
Unable to load library.
(19151:3:3)
OK
Read more
I am not sure if this is the correct place to publish my query. I downloaded MapleStory on my Windows Vista Home Premium 32-Bit PC.
Today, as I was trying to launch it through Directory Video Game Launcher, in my desktop or even in the MS website, I got a problem stating “MapleStory has stopped working.” What is causing this?
How can I resolve this issue?
Microsoft Windows
A problem caused the program to stop working correctly.
Windows will close the program and notify you if a solution is available.
Close program
Read more
Hi Guys,
I am using Wordpress theme when i click at picture (copy image location) in Mozilla Firefox for copying image location then anyone know that i am using the theme.
Please any one tell me how can i hide this thing. I want picture can't know that i am using some theme.
Thanks for your time.
Read more
I am receiving the following errors on my Windows Server 2003. I am using Retrospect 7.6.2.101. The error is “Can't access volume xxxx error -1102 (drive missing/unavailable). Trouble reading files, error -1221 (can't access database).” How do I resolve the error? Please help.
Read more
