Archive
I am using Retrospect backup software to backup my system for years. Recently I had a problem with my computer. The restore CD doesn’t worked and hence had to reinstall the entire OS and update it. Then I installed Retrospect and its updates. Later while trying to backup, I got the error 1017. I had a research and tried the available resolutions. Now I am able to complete the backup but with error 8000. Then I downloaded free backup software and finished the backup process without any errors. Now I would like to restore the Retrospect backup and on...
Read more
When trying to recreate the catalog in Retrospect Program to complete the system restore, the following errors are displayed: Error 102 (trouble communicating) Error 205 (lost access to storage medium). What is causing the issue? How can this be solved? Any help will be appreciated?
Read more
Recently, I have downloaded Desktop Dungeons 0.151 for windows. Then, I received the following information right after double-clicking the icon of Dungeon on my desktop. The first error is stating “Desktop dungeons has caused an error in <unknown>. Desktop dungeons will now close. If you continue to experience problems, try restarting your computer.”
When I clicked on the Close button, another error occurs:“Failed to load the game data. File seems corrupted.”
When I hit OK, nothing happened. It will just close the error box. I am thinking...
Read more
I am trying to sign-in with Garena Messenger Beta but I got this error message:
Garena Messenger
Error Signature
AppName: garenamessenger.exe                          AppVEr: 1.1.6.5          ModName: unknown
ModVer: 0.0.0.0    Offset: 00000000
I uninstalled the program and reinstalled it back again hoping that it will fix the issue but it didn’t help. And also, I tried running the Garena.ntt.bat and get this:
Ping data for 174.36.72.44:
Packets: Sent = 12, Obtained = 12, Missing = 0 (0% missing),
Estimated around journey times in milliseconds:
Minimal = 227ms, Optimum = 232ms, Regular = 229ms
This error also appeared. It seems that there is a missing .dll file that...
Read more
Recently, I started to receive this issue with working with Yahoo Instant Messaging. The moment I press on the friends list to launch the Messenger, a problem will show up with the information "Not enough storage is available to complete this operation."
Here is the image of the error:
Internet Explorer Script Error
An error has occurred in the script on this page.
Line: 7
Char: 81
Error: Not enough storage is available to complete this operation.
Code: 0
URL: file:///C:/Program%
20Files/Yahoo!/Messenger/x3KLHNm73MpDXnafulGr2w-
Do you want to continue running scripts on this page?
Read more
I am using Windows 7 x64 with GameBooster 1.3 installed on it. I received this problem as I press on
Display All Latest Procedures. What should I do?
Game Booster
Could not convert variant of type (Null) into type (Olestr)
Read more
Hi guys, I need to import a bulk CSV file to CUBRID Database Management. Because the speed of the process is very low, I decided to download the CUBRID Migration Toolkit (CMT). Then, I opened the CSV file in MySQL.
The process took 30 minutes before it finished. I attempt to create a CUBRID table and then transmit it to a MySQL Database to CUBRID Database. When done with the transmission, the table is already indexed.
And now, when I am trying to run the Database, I keep getting an error shown below:
Progress Information
Running.
Start database "backtesting".
Read more
One of my clients has an issue using a particular USB disk drive for backing up. He is receiving the error “Error-105 unexpected end of data.” on Retrospect Multi Server version 7.6.123. I have tried re-cataloging but failed. I did chkdsk /r which completed successfully. But on starting Retrospect again, it failed. Why is it caused using on this USB? How can I get this solved?
Read more
I have SQL 2008 Database installed on Windows 2003 server. But I am receiving Error 1221 and error 1102 during the backup process. I have searched everywhere but I could not find a perfect solution. Can anybody suggest any solution?
Read more
I am receiving Error 1103 on Retrospect Pro 7.6. I am using this product for years and never had any problems before. Sometime it states that I am unable to create backup and sometime it cannot create catalogs. The frequency of error seems to be increasing in every use. Other than this, the backing up and restoring of files seems to be working fine. My computer is not connected to any network. How do I get rid of this error? Please help.
Read more
