Archive
After receiving an error, I am unable to view the list of emails that my Retrospect version 7.7.562 software failed to back up. I used to see this by clicking the “Errors” options under Job History but now it is grayed out. Please suggest a solution to get this resolved.
Read more
My computer has been attacked by malicious threats plus some issues which I frequently encountered; I was unlucky to save my hard disk. So I need to replace it with a new one.
With the new hard disk, while I’m trying to install Windows XP in it, I keep getting errors and issues. So I wonder if there are some mistakes in setting up Windows XP. Can someone here send me a procedure on how to do it properly? Thank you.
Read more
I want to uninstall outdated version of iTunes but I keep receiving an error 1606 and I was unable to continue with the installation. I tried to uninstall it anywhere but the error just keeps on popping up. Can you be able to provide any help to resolve the issue?
Read more
I cannot get the Nero Vision Xtra software to burn a Blu-ray disk as an error is displayed even before starting the encoding process. What can be done to avoid the error? I am running Windows 7. Please help.
Read more
I encountered series of errors and problems with my computer so I decided to do System Restore. When I am done restoring a project file from my backup, the video clips and images are showing with no frame. During the uploading process I got a message stating that some files are missing and the procedure to locate them manually which I followed correctly.
I am able to play them outside VideoPad 2 although some of the files play only the sound part in VideoPad. I am also unable to play the preview of the project. How can I retrieve my...
Read more
My Mac PC is running with OS X 10.5.8. It has Prism Video Converter software downloaded and installed in it. I have some m4v files which I need to convert. I made those files in iMovie and every time I started on converting, an error is showing that says "Could not open source video file."
Can anyone suggest any solution for this problem?
Read more
I am using Retrospect version 7.7.562 for Windows. I could find a readme file along with the application that says "RET-235: Fixed a crash (elem.cpp-1138 assert) that could occur when Retrospect sent a cleaning cycle command to a tape library while another operation was running." But I am unable to locate any tape library. How does this happen? What should I do if the crash happens?
Read more
The Retrospect Small Business Server Premium Version 7.7 runs on my Windows SBS 2008 machine without any errors. But lately, it started throwing an error message stating "Assert - module.cpp-1138." What is this? How can I resolve it?
Read more
I’ve been using Retrospect Professional 7.7.562 for quite some time now on my Windows 7 PC. Just today, an error appeared on my screen while doing the backup process. The error is stating “Grooming Backup Set Backup Set A failed, error -1017 (insufficient permissions).
You must recreate the Backup Set's Catalog File.” This is the only time that I got an error from Retrospect. And also, when trying to create a Catalog file, another error occurred stating “Can't load Snapshot tree, error -641 (chunk checksum didn't match).” So I did a Recycle backup and receive 56 errors “Backup Set format...
Read more
I am trying to backup my .pst file but an Error 1111 is appearing so I could not continue. The error occurs after upgrading Retrospect Single Server Edition Version 7.7 for Windows Vista. What do I need to change in Retrospect settings to continue with the back up? Can I use it in backing up an open file? Please send me some ideas. Thanks.
Read more
