Archive
Hi All,
In my home computer which has Windows 7. I get this error in the event logs.
Your computer was not assigned an address from the network (by the DHCP Server) for the Network Card with network address 0x544598479210. The following error occurred: 0x79. Your computer will continue to try and obtain an address on its own from the network address (DHCP) server.
Can anyone help to solve.
Regards
Read moreBacking up a 1.6TB Workspace to 3 LTO4 tapes using a Tandberg TS400 Robotic was successfully completed. However during the verification process, I received an Error 102 which is a connection issue I guess. This is caused due to the failure of our RAID drives during the process. I would like to know whether it is possible to verify a particular tape in a multi-tape backup.
Read moreI keep receiving an error message "PARM_GETVIDEOSATA-ERR" when trying to edit .flv files in Squeeze 4. What does this mean? How do I resolve it? I am running Windows Vista SP2. Please help.
Read more
Hi there!
My office computer fan makes very loud sound noise. It is very boring for me. At last I have been deciding stop this fan. But if I stop CPU fan so my processor will be risky.
Thanks
Read moreWhile trying to transcode a MPEG-2 MXF file into Apple ProRes 422 HQ using Episode 6.1.2 installed on my Mac OS X Snow Leopard system I received the following error message: “Exporter Error: No frames in Queue nr. 0.” What does this means? However, they do accept certain Mpeg file. But I cannot identify any difference between those that are accepted and not. Any help will be appreciated.
Read moreI purchased Episode 6.0.1.3 for $295 to use the full features. I installed it using the serial key provided. But on trying to access the application, I receive the error message “Could not connect to EpisodeAssistant process. Application needs to quit." Can anyone help me with this issue? Currently I am using my old version but really love to try the new one. Help please.
Read moreI have my Mac and Windows PC connected to the same network and both have the latest version of Episode installed on them. I am able to see, submit and encode clusters using Episode on Windows PC. But on Mac, I am able to see it, but other processes end by with an error. All other systems in the network are working fine. I have tried uninstalling and reinstalling it with no help. What can be done?
Read moreI got a blue screen "bad_pool_caller" error and the computer shuts down on streaming a video. I have done this without any problem before. What may be causing the issue? I have run CCleaner, Malwarebytes and even tried restoring the computer without any luck so please help. I am running Windows XP Professional.
Read more
When I open some application on my pc some of the application, some will not open, some used to report oleacc.dll not found others report error log at 0xc0000142. I do not really understand what that means but I think you can have a solution.
Read more
I received a blue screen error on my computer and get the details of the error as the system restarts immediately. So I rebooted the system and pressed F8 to open the Advanced Boot Options.
Choose Advanced Options for: Microsoft Windows
(Use the arrow keys to highlight your choice.)
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable low-resolution video (640x488)
Last known Good Configuration
Directory Services Restore Mode
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Start Windows NorMally
Description: Prevent...
