Archive
I had a problem with a Windows Vista Home Premium 32-bit and it was not booting. I did a Master Boot Record (MBR) repair and it got fixed. I then tried booting it numerous times without any issues and handed it over to a client. But now it is displaying “Error 0xc000000f. An error occurred while attempting to read the boot configuration data.” I did a Master Boot Record (MBR) repair; it booted without any problem and then showed the same error message. I did Seagate diagnostic, but it couldn’t identify any problem. I have tried all the possible...
Read moreI recently downloaded MediaCoder 2011 Build 5002. And when trying to encode the audio part alone, I received an error message. I have a video file that contains two audio tracks and encode the audio only. The settings are:
MKV File
Encode: Nero Encoder
Format: HE-AAC V2
Source: Mplayer
Resample: Original
48Kbps with normalization
Hint track Enable
Dual Audio Track Select
I have tried following the same process in MediaCoder 0.7.3 Build 4600 and was able to complete it without any error. What is causing the error in build 5002? How can I resolve it?
Read moreI am using a Windows 7 computer and after installing MediaCoder 2011 x64 package, I started receiving an error “MediaCoder is unable to connect to Internet. Some enhanced features will be disabled. Please check your Internet configuration.” When I clicked on the OK button, it directs me to a welcome window with “Start Config Wizard' or 'Start MediaCoder' options. When selecting the first option, it directs me to UI. When trying to convert Free Lossless Audio Codec (FLAC) to mp3, I get an error stated below:
Problem signature:
Problem Event Name: APPCRASH
Application Name: AudioCoder.exe
Application Version: 0.6.1.0
Application Timestamp:...
I have Quick Media Converter HD Version 4.5.0.0 installed on my Windows 7 Home Edition x64 with SP1. The computer has Intel Pentium Dual Core CPU E5400 @ 2.70 GHz and 4GB RAM. I have used the QMC software to convert YouTube .flv files to mp3. But now I am unable to perform that because of the error. The details of the error is provided below:
FFmpeg version SVN-r22666, Copyright (c) 2000-2010 the FFmpeg developers
built on Mar 25 2010 06:05:35 with gcc 4.4.2
configuration: --enable-memalign-hack --cross-prefix=i686-mingw32- --cc=ccache-i686-mingw32-gcc --arch=i686 --target-os=mingw32 --enable-runtime-cpudetect --enable-avisynth --enable-gpl --enable-version3 --enable-bzlib --enable-libgsm --enable-libfaad --enable-pthreads --enable-libvorbis --enable-libtheora --enable-libspeex --enable-libmp3lame --enable-libopenjpeg --enable-libxvid --enable-libschroedinger --enable-libx264 --enable-libopencore_amrwb --enable-libopencore_amrnb
libavutil 50.12. 0 / 50.12. 0
libavcodec 52.60. 0 / 52.60. 0
libavformat 52.57. 1 / 52.57. 1
libavdevice 52. 2. 0 / 52. 2. 0
libswscale 0.10. 0 / 0.10. 0
C:UserskarenDownloadsVideo?Jason Derulo - Don't Wanna Go Home...
The TMPGEnc program displays “Error occurred....0xC00D36B2" when editing the timeline of my video or when I am applying Filter effect. I am running this on my Windows 7 PC and Windows Media Player 11. I don’t have problems using these programs before. I also used Avid Media Composer. How can I get this done? Please send me some help.
Read moreOn starting the TMPGEnc program, I am receiving "Application error: EAccessViolation in module TMPGEncVMW5.exe/689E99E9. Reading error occurred in address 689EA9E9 at address 689EA9E9.” followed by "FastMM has detected a GetMem call after FastMM was uninstalled." The Task Manager shows that TMPGEncVMW5.exe uses almost 100% of the CPU. I have tried reinstalling the program. But it didn’t help resolve the issue. Please help.
Read moreI am using TMPGEnc on my Acer computer with Windows 7 installed and recently I am receiving an error message. Before, the issues it used to get resolved on installing and uninstalling the K-Lite codec pack. But nowadays it doesn’t work. The error occurs whatever we do at any point of time. It appears on the beginning of every work. And when I already completed the project in 50%, it cannot be displayed. I also get stacked on a black window. Can anyone help me out? Please.
Read moreAm I receiving the following error because there are no tasks to display the logs in the custom view? Is so, how can I resolve it? And if not, what is the possible cause of this Event Viewer Error? I am using Windows Vista. Thanks for the help.
Administrative Events
Event Viewer
Event Viewer cannot open the event log or custom view. Verify that Event Log service is running, or query is too long. The specified query is invalid (15001)
Can anyone help me and explain the procedure to get rid of this Microsoft Visual C++ Runtime Error? I am running Windows Vista. Thanks.
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: C:Program FilesFileZillaFileZilla.exe
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
OK
I am receiving the following error window on starting my Windows 7 computer, and I don’t know which program is causing this error to appear. How can I identify it?
Please help me get rid of this.
Error:
Keychanger.exe - System Error
The program can't start because kbdhook.dll is missing from your
computer. Try reinstalling the program to fix this problem.
