Archive
How do I stop my computer from displaying Error codes 0107, 0122 and 0132 while playing Blu-ray movies? Any help will be appreciated.
Read more
I purchased a full version of Corel VideoStudio Pro X4 and installed it on my computer. Everything was working fine until I tried adding rain effects to a large movie file. I got a message that there is no enough space and the FX thumbnails disappeared. I tried reopening the program but resulted in the following errors: “Error loading from stream" and then "Videostudio Pro has encountered an unspecific error and needs to close, please contact Corel Support and include a copy of the Dump file.” The error appears every time I load the program. How do I resolve...
Read more
I am trying to create a video using Corel VideoStudio but it keeps stopping. Then I decided to try restarting the application after saving the project. Immediately a message popped up stating “SP1 is available for download” and I did it. Now I am receiving the following error message: “Error: 38 - Corel VideoStudio files have been damaged or modified. Please reinstall your original source”. Am I having the issue because of installing SP1? How can I solve it?
Read more
I had the trial version of Corel VideoStudio Pro X4 installed on my computer and later I bought and installed the full version. I had a problem after installing SP1 and the application stopped working. I had to restart it and hence lost all the unsaved data. So I uninstalled the trial version and reinstalled the application from the disc. It worked fine but later on, I had a problem with the security program. So I did a system restore but now I am unable to access the program and receive the error “Error 4: Corel VideoStudio files have...
Read more
I am trying to install a trial version of ShowBiz DVD 2 and when done with the installation, I tried to update it to ShowBiz DVD 2.2.2.109. Then I started to create my DVD using it but when I clicked the “Write Disk” button, I received the message “An error occurred while rendering the motion menu."And I also got the message “Failure writing the disk" attempting to start burning my DVD. What is wrong with it? How can I sort it out?
Read more
I am receiving an error message while trying to create a DVD burnable file using AVS Video Editor. The error message is “Access violation at address 005B07B0 in Module AVSVideoEditor.exe Read of Address 0000000”. I never had any issues before though I have not used the toll for the last one year. Please help me resolve it.
Read more
The error message “Can't load project. It can be missing or corrupted” is displayed when I try to load an .avi file that I have created and saved using my AVS Video Editor 5.2. Last time, I clicked the “Produce” button to save it but its not opening. What can be done to open the file without any errors?
Read more
I am doing a project that need to add multiple bins Avid ProRes 444 AMA material. But recently, I am receiving a “Serious error” message for numerous times now. Does anyone here who has the same issue as mine? Why is it so? How can I resolve it?
Read more
I got an error while initializing Avid Media Composer  v5.5.3 software on my Mac PC. I choose custom installation to install AMC alone and activated via dongle option. Is it because something went wrong during the installation process? How can I resolve the problem?
Read more
I am receiving “Can’t continue because Avid Studio requires Vista Service Pack 2" error on my Windows 7 64-bit computer while trying to install Avid Studio software. Before that I used to get "Error 1305" and I am not able to proceed with the installation. What should I do to fix it? Please help.
Read more
