Archive
I am receiving “Can’t continue because Avid Studio requires Vista Service Pack 2" error on my Windows 7 64-bit computer while trying to install Avid Studio software. Before that I used to get "Error 1305" and I am not able to proceed with the installation. What should I do to fix it? Please help.
Read moreI am trying to install CorelDRAW software on my Windows 7 computer and get stacked with the “Please wait while we configure DirectX” window. Then it closes the installation process followed by the error messages below:
DXSETUP.exe - Bad Image
C:WindowsMicrosoft.NETFrameworkv2.0.5727mscorwks.dll is either not designed to run on Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for support.
dxsetup.exe - .NET Framework Initialization Error
C:WindowsMicrosoft.NETFrameworkv2.0.50727 could not be loaded
Installation Wizard not complete
Your system has not been modified. To complete installation at another time,...
I have Audacity 1.2.6 installed and it started throwing errors while trying to record Long Playing (LP) recording. I completed one side of the record without problem. On turning the other side and start recording the Audio track, I got message that appears for almost 10 times per second and I was unable to cancel it. The error states: "Cannot open file 'C:UsersadminAppDataLocalTempaudacity_1_2_tempb00590.aub00710.au' (Error3 : The System cannot find the specified path) Date,Time…" On searching the file using the Command option shows:
Verzeichnis von C:UsersadminAppDataLocalTempaudacity_1_2_temp
09.01.2011 20:34 <DIR> .
09.01.2011 20:34 <DIR> ..
09.01.2011 20:03 1.060.956 b00000.au
09.01.2011 20:03...
I keep receiving "Error: Application unable to start correctly. Error code 0xc00000a5." When trying to access Google Chrome on my Windows 7 computer. It was working before. I have searched in Google about the error and found that a lot of people have the same issue. When trying to uninstall and reinstall the program, it did not help at all. How can I resolve it?
Read moreI am receiving an error message that says “The procedure entry point MpHeapReAlloc could not be located in the dynamic link library ODBC.dll.” on opening Pinnacle Studio 10 installed on my Windows 7 computer. I believe it is compatible with Windows XP. Pinnacle media manager, instant DVD Recorder and Studio Tutorial are working fine. Why am I receiving this error message?
Read moreI got a message while importing a .mov file to Adobe Premiere Pro CS4.
The error message is 'Codec missing or unavailable'.
How can I import the file or where can I get the required codec.
Any help will be appreciated.
Read moreI am unable to download Sony Vegas 10 on my HP computer running Windows 7 64-Bit from Vegas official website. On clicking the install button, it downloads 1/3 of the file and ceases with the error message, Error 1603. Please help.
Read moreI am receiving the following error message while trying to access After Effects CS4 after reinstalling Windows Vista on my computer: "After Effects error: can’t get Unicode file." If I click OK, I am able to use the program but when I try to watch a tutorial online, I get the error: "After Effects error: failed to parse transmap file." Then, if I want to quit the program, I have to use the Task Manager. Its working fine on another computer. Please help me fix it.
Read moreMy Adobe After Effects CS5.5 software is displaying Error 3 or Error 6 while using it. It works perfectly fine for 2-3 uses after installing it. Later it throws the error message and I have to repeat the whole process of installation. How can I get rid of this?
Read moreI have Adobe InCopy and InDesign CS4 installed on my Mac computer. Recently I am receiving an error message which states “Galley View and Story View are not available as the document do not contain InCopy stories.” I have tried importing the InCopy assignment to layers and selection but the error persists. What should I perform to get the issue solved?
Read more
