Archive
I have a Windows Vista Home Premium PC. While I am trying to install the latest version of Adobe Acrobat Reader, I end up with an error message: "Error loading AcroFill.api!! Adobe Acrobat Reader has encountered a problem and must be shut down. We apologize for the inconvenience." Please help me resolve the issue. Thank you.
Read more
I have created an .mp4 video file that works on DirectShow. I used ffdshow codec pack with my Windows XP computer and it works without any issues. But I have tried it with Windows Vista and Windows 7 PC, and I could not make it work. I already configured a lot of settings to make .mp4 file works, but I have no luck. When I tried to alter the backend to MF (Media Foundation), it works. But the problem is it won’t work with my Windows XP computer.  The default codec is set to ffdshow already but it is...
Read more
I cannot play a .mov file using QuickTime player as it shows the error message “QuickTime player has encountered a problem and needs to close” or restart the computer after pausing at the below provided screen. I have tried installing the latest version of QT player after uninstalling it completely from the computer.
I have scanned the computer for any virus or malware and even formatted and reinstall my Windows Vista OS. But nothing worked. I am also unable to play the file in other players like K-Lite, VLC and GOM. They are also not working.
Any suggestion on how I...
Read more
While playing Minecraft, my computer closes the game window and opens Notepad with hs_err_pid error. I have tried reinstalling the game and installed different version of Java. I have also scanned my computer using Antivirus, Anti-Malware, and Spy Sweeper and then update my Windows Ultimate computer with Service Pack 1. I installed the updated drivers for all the hardwares like Graphics and Sound cards but it doesn’t help. Can you suggest a resolution to get out of the issue? Any help will be appreciated.
Read more
Recently I noticed that while browsing the internet, the screen goes black or flicker and recover the original state followed by an error message under the taskbar stating that the Nvidia driver has failed and Windows is recovering from a serious error. I then check the Action Center and could find certain Video hardware errors listed. This error remains and I encountered similar issue while playing WoW game last December. But I didn’t check the Action Center then. I tried reinstalling the video card and update all the drivers. But the problem still persists. I am using a Windows...
Read more
I have Windows XP installed on two partitions of my computer system. The Drive K: is the default drive while Drive C: is a fall back option if Drive K fails to load. But now when I try to log to the default OS, it throws a blue screen error message and redirects me back to OS choice window. I have tried to repair it by running Chkdsk/r, boot using Safe Mode, scanned for viruses using AVG 2012 and also used MalwareBytes to scan the Drive K: but I am still receiving the same error. What shall I do...
Read more
I need to send out my project which I created in Final Studio 3 to Quicktime DV NTSC 48 kHz Anamorphic but I keep getting an error on exporting it. I already tried to create a new timeline but it did not help. I even tried changing the aspect ratio and checked on the hard disk usage but only receive the same problem. Please help me resolve the issue.
Read more
In the process of network streaming, when I input the URL on the song that needed to be streamed, I receive the following error message. “VLC media player just crashed. Do you want to send a bug report to the developer’s team?" I have reported this to the team but no one helped. What do I do now?
Read more
I would like to install X264.exe video codec on my Windows Vista computer which I have downloaded from X264.nl. But I get a ‘No input file’ error message. What can be done to install X264 successfully?
Read more
Please help me overcome the following situation. I loaded an AVI video into VirtualDub and saved it by FFDShow compression setting the filter in standard configuration.
Later, as I need to make some changes in the video, I reloaded it in VDub and tried to play but ended up with an error.
I have performed the process before without any problem, but I am unable to do it now after restoring my computer to default factory settings.
What should I do?
VirtualDub Error
Error decompressing video frame 6868:
VirtualDub cannot decode 4:2:2 Motion JPEG frames with image widths or heights that...
Read more
