Archive
After encoding one episode of a TV show that I ripped from the DVD, I am receiving the error below. I am using Windows 7 with Intel Core i5 2500k Processor. The error is stated below:
Win32 Version: 4.0.30319.236 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
SplitButton
Assembly Version: 2.1.0.0
Win32 Version: 2.1.0.0
CodeBase: file:///C:/Program%20Files/Handbrake/SplitButton.DLL
Accessibility
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.1 built by: RTMRel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must...
I want to convert a series of 60 720X576 pixel images (the filenames are arranged in order from tc_00.gif to tc_59.gif) into a 60 second MPEG2 video at a 2920kb/s rate. After which, I need to transmit the video using Digital Amateur TV (D-ATV) mixed with a transport stream. My encoding command line is “ffmpeg -i tc_%02d.gif -r 1 -y -an -vcodec mpeg2video -b 2920kb -r 25 -s 720x576 TC_ZL3JVX.mpg.” However, I am receiving the following error message during the encoding process: “Unable to find a suitable output format for TC_ZL3JVX.mpg.” What should I do to get rid of...
Read moreI would like to set up and install Ubuntu and then dual boot it with Windows 7 until I become comfortable using it. I am using the Windows Installer Wubi for the process,and I am installing it on a 30GB partition in drive C. But I am receiving an error. I have tried all the possible solutions that are available in the internet, but nothing helps. The screenshots of the error are shown below:
I have a Windows XP Professional Service Pack 3.When I check the Dynamic Host Configuration Protocol DHCP service, It stops automatically. And when I start the service, nothing happens; it only shows the error “Could not start the DHCP Client service on Local Computer.” It comes with an Error 1068. And also, the reliance service or group is unsuccessful to start. Can someone lend a hand and help me on this? Thanks.
Read moreHow could I configure a Network-Attached Storage (NAS) tools on the system and connection direct to the accounts? Is it necessary to establish security here or that the device is an extension of one of my Windows Servers using their safety? What was the common exercise? Help please.
Read moreHow could I send email files to be viewed in Excel from the software that is written in Visual Basic 6 (VB6), so that when the receiver opens the Excel book, it will not only shows the data but copies all the codes?
Can you get my point?
If so, please send me some help.
Read moreHow do you get rid of this message that pops up on your computer screen with almost every mouse click; “Document has encountered a problem and needs to close.” Can I send this problem in Microsoft? I am running Windows XP Pro Service Pack 2. Please send me some help and suggestions. Thanks.
Read moreI have a customer that needs an implementation to a Disaster Recovery (DR) site using only secondary Cisco gear. Is there someone here who could give me suggestions or a guide for best probable solutions, and desirable manuals for this matter? Thank you very much in advance.
Read moreI am looking for help to make RepRap and I think CAD tools will help to end up modding it and build derivative. I am just a beginner with CAD. But all CAD programs which I choose demand a lot of learning. I cannot try another one as it will cause more costs. I am looking for suggestions for good CAD programs otherwise I have to learn all CAD programs. Since I am affiliated to a University, I can access Autodesk without any charges. Also, I can get subscription of ‘SolidWorks’ at a low cost of $55 per year...
Read moreI am using PC with Windows 7 Professional 64-bit and 8GB RAM. When I am importing a PDF file with 2 hatches which contains simple architectural drawing, it is not getting done. Other PDF files which have made with PDF995 are making no problems. Those files are simple small hatches and files with 11x17 with short details. The drawings are made with the ‘TurboCAD’ and created PDF. I am not in a position to check with other software. It keeps crashing when I draw x5 after the dialogue box for text options and when I am clicking on OK...
Read more
