Archive
Hello everyone,
I would like to send group emails. My contacts are located in Outlook. However, I cannot send group emails through Outlook. I tried to solve this by using mail merge with MS Word. However, whenever I do this, a pop-up appears for each contact and I need to click 'yes'.
This is very tedious. Can anyone help me send group mails through Outlook or if not, how do I make the pop-up disappear?
Read more
How should I configure Windows 7 not to shutdown automatically? I found out that when you restart Windows 7 as the default setting, it would be a security risk which can be the reason for widespread loss of data and also defects. I do a back-up during the evening and copy a large database. However, my computer automatically shuts down since this is the default setting on my Win7.
What step-by-step procedure should I follow to prevent this from happening again?
Read more
Hi!
My hard drive has different partitions and I recently installed WDP. It says that the installation was successful. However, Whenever I revert to Windows 7, it won't run. I tried all the repairing options but all to no avail. I read that I am not the only one with this problem but I haven't read one that showed a solution.
Hopefully, you could help me.
Read more
This is so frustrating. I could not seem to solve this problem. At first, my flash player was working with Firefox 3.6.9 but I had difficulty in scrolling so I upgraded to Firefox 7. Now, my flash player would not work. I already tried to re-install flash but to no avail. What should I do?
Read more
I have lot of questions regarding adopting cloud solutions. Please do go over my questions and if possible answer all of them. I really need answers to these questions. When I switch to cloud, what will now happen with the data center? What businesses, type of work, load on work would be most suitable or compatible with cloud? Do you see a trend wherein all cloud would be the solution for all the workloads?
Wouldn't it be costly if you run the workloads all day with cloud? Do you also see a trend with ISVS shifting to cloud?
Read more
For my OS, I trust Linux that's why I use it most of the time. However, whenever I switch on my computer with vista, the new firewall would show me a notification which shows that consent.exe needs TCP (outgoing). Why is this so? I tried to search for answers in the net and found out that there are people who have problems like mine. Why would it need to enter the net? Do you know where this is coming from?
Should I block these as a general practice?
Read more
Cloud hosting has been creating so much buzz not only to individuals but also to large corporations. I heard that most have shifted to cloud recently. Could the cloud also cater to small businesses in the internet? Why is it that only large businesses are shifting to cloud? Why will the e-commerce business not shift to cloud hosts?
Read more
I would like to be able to publicly search online particular locations. Is it possible to record a location on search engines that will be available to the online public, provided that I have the exact coordinates?
Read more
Is there any way I can find out the signal strength I will get for a particular internet and telecommunications service? I was given a reference for comparison but I still want to make sure that I will get good value for my purchase by having good signal for the services that I subscribe to.
Read more
I tried repairing some issues with my video card and used methods that I have acquired from searching the internet. Apparently, it worsened the situation because now I am just getting a stop error whenever I turn on my machine. I ran the troubleshoot program and it indicated that I do not have a video card, could the video card be broken or should I just remove and restore the program again?
Read more
