Archive
I want to replace my old video card with a 5400 series of Evergreen graphics processing unit. Will an NVIDIA main board process is this particular series of video card?
Read moreI’d like to ask if you know of any retailer that has an available built-in antenna electrical cable for a Motorola smart phone? I saw some parts that somehow resembled this connector but they do not fit, I intend to change mine and if you can help me look for one, thanks.
Read moreIt takes me a while longer to open a folder in my portable computer that has the latest Windows operating system and processor installed. The size of the folder is quite big consisting of a thousand files. The folder eventually opens, but I would like to ask if this is really what happens given the circumstances or is this a problem that I need to resolve?
Read moreWhen I checked my computer temperature reports in several utilities, the turnout was inconsistent. Can you please give me insights as to what caused this irregularity? Could it be an external device that was plugged in to the machine?
Read moreHi guys!
I have another problem that I’m hoping you guys can help me with. Aside from the fact that my PC is slow, I can’t use the regedit, task manager and search button. I have no idea why I can’t access them, it says “The task Manager has been disabled by the Administrator” and it is also the same message with the regedit. As for the Search button I can’t find them.
Please help!
Read moreMy HTC Passion’s touch screen function is dysfunctional; this is what happens when I open my phone’s system. However, when I restart it from hibernate mode, the issue is resolved. Can you please help me identify what the problem is? I’m not sure if it is my operating system but I am just using the default android system, or is it a factory defect and I should demand that the manufacturer replace it with a working unit?
Read moreWhen you choose a computer’s data rate processor, what are the distinctions of the two latest versions aside from the data rate per second like other applications?
Read moreMy disk storage firmware is not reading data nor is it even physically opening the drive. I checked the tool settings, which indicated that it should be functioning well and I even hoped that deleting then re-establishing the program that ran the device will solve the issue but I was not successful. Could it be a problem with physical parts of the firmware? Can you please help me on how to make my device work?
Read moreThe following error message pop ups on my Windows 7 computer when I try to play a .TS file: The decompression codec cannot decompress to an RGB format. This is very unusual. Check that any "Force YUY2" options are not enabled in the codec's properties.
I have tried checking and un-checking the “Directly decode uncompressed YCbCr (YUY) sources” option under Options Preferences which never made any difference. I am also unable to load a .MTS file format as it is not listed in the file type. If I upload it by selecting “List all files”, I am receiving the below...
Read moreI want to have Nukex installed on my computer. I tried to install a manipulated version of Nuke 6.3v4 which do not worked. Later I downloaded the PLE version. Now I am able to access Nuke 6.3v4 using the desktop icon. But while trying to open the PLE version by clicking its icon, I get the following error message: Foundry error: Broken cache chain 000000000102D844 What should I do resolve the error?
Read more
