Archive
I am receiving a message stating the “3D Studio Max is already installed on the computer” while trying to install it. Though I have installed it before I believe that it was successfully uninstalled. I have also tried using the Diagnostic tool, Safe mode and association tool. How can I successfully install 3D Studio Max on my computer?
Read more
I am receiving the following error message while trying to install Microsoft Office Word on my Dell computer pre-installed with Windows XP Professional: Error: 1402. Could not open key H-key_local_machinesoftwaremicrosoftwindows currentversionrunoptionalcomponentsmsfs.
Verify that you have sufficient access to that key or contact your support personnel. Can anyone help me solve the issue?
Read more
I got the following error message while trying to install the Virtual Sound Processor, that I have downloaded, on my Windows 7 computer with AMD Quad Core 4 processor: Error: 0x80040702, Failed to load dll: SpazInst Is the software compatible with Windows 7 or do I have to follow any process to resolve the issue?
Read more
My Windows 7 computer is throwing almost 7 Java error messages. I have tried contacting Java but never got any reply. Is this problem caused because of downloading Oracle Office? Other than this my computer is found to be working fine. The numbers of the errors are as follows: 296, 4312, 2688, 3016, 3088.
How can I resolve those issues?
Read more
I am trying to encode a 16-bit grayscale image to movie using FFmpeg SVN-r0.5.1-4:0.5.1-1 Ubuntu1.1. I am using FLV1 codec but the pixel format changes to YUV420. I think the codec is not compatible with the colour space and I am receiving the following error: "Incompatible pixel format 'gray16be' for codec 'ffv1', auto-selecting format 'yuv420p'" I have also tried the raw video but ended up in container compatibility issue. I couldn’t find any codec that satisfies both the colour space and container requirements.
Please help me resolve the issue.
What should I do?
Read more
I am unable to perform a clean installation of Ubuntu 11.10 using the 32-bit or 64-bit installation CD on my dual boot computer as the screen breaks to a black background with a cursor without proceeding to the installation process. I am able to successfully complete the 64-bit installation process using a USB stick but on restarting the computer, it throws the following error message: “Error: invalid arch independent ELF magic”
Can anyone help me to resolve the issue?
Read more
I was using Lightworks on my 32-bit computer and had to shift it to a 64-bit computer that have more memory space. After few days. I received the error message “Unlicensed - Install License File". I have verified NTP date, uninstalled the old version and installed the latest version of Lightworks, provided new machine number and tried all the possible solutions.
Nothing worked. How can I resolve the error?
Read more
My computer is Windows XP Home Edition SP3. I downloaded the trial version of EDIUS 6 and unzipped the folder. I double clicked the SetupManagerForEDIUS.exe file according to the instruction. But file didn’t open. Clicking the Setup.exe threw a "License agreement" window along with an error “17001 - System error". I have Let's Edit software installed on my computer. I have tried installing EDIUS 4 trial version before but uninstalled it. Why am I receiving the error? How can I resolve it?
Read more
Hi there again!
     My 500gb Hard Disk has become noisy and creating a buzzing sound these past few days and I’m worried that there might be something wrong with it. I tried checking it by removing it from the unit and shaking it if there is some loose components inside. I found out that it is still intact so I attach it again to the unit and there it is again. My computer still functions and still loading but I noticed that it took longer than usual to load the desktop…what’s wrong? Is it time for me to replace...
Read more
Hello there guys!
Just want to ask what is the best graphics card to run SHOGUN 2 and WARHAMMER: Spacemarines, since I've been waiting for it for some time and my current graphics card cannot run it without lagging and it's too slow. I want to know the next best graphics card but also cheap since my budget is limited.
My Current Specs:
Athlon X2 250 3 GHz.
2 GB Memory.
Radeon HD5450 1 GB Graphics card.
500 GB Hard Disk.
Thanks in advance!
Read more
